Home > For Sale & Wanted > [Wanted] Series bits
Shroppy
United Kingdom 1986 Defender 130 V8 Petrol HCPU Aintree Green
I appreciate this is a little OT but, as many of us on here have Series LRs I'm hoping someone may have the following for sale;
- 109 Canvas and hoodsticks (happy to buy separately or parts thereof)
- Hardtop, sides and catflap
- 3 Bolt tailgate
- Tailgate cappings for rear tub
- Rear floor x-members / 109 tub I can use for spares
- Glass lens type side lights / indicator assemblies or parts
- Sprung type seat bases
- Wing mirror heads
- Anything else you think may be useful for this;
I'm keen to keep the vehicle looking as original as possible so weathered parts are ideal. Also happy to travel or arrange a courier.
Many thanks in advance. 1985 127 V8 Build Thread
Series 2 109"
Series 1 80"
Post #911293 7th Jul 2021 9:38pm
excossack
Glass lenses with the little tags/wings on the outside, screw on type? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #911345 8th Jul 2021 9:14am
Shroppy
This type, though I'm not 100% sure if they are correct?
Series 2 109"
Series 1 80"
Post #911350 8th Jul 2021 9:45am
excossack
I think the ones i have are different,
Can WhatsApp pics if you want? 1999 Defender TD5 110
Regards
John M0VAZ
Post #911352 8th Jul 2021 9:48am
I suspect that when new it would have been fitted with Lucas L488 sidelight units at the front (https://www.holden.co.uk/p/lucas_l488_type_sidelamp_single_contact) and no indicator lights. The indicators when fitted would most likely have been Lucas L549 (https://www.holden.co.uk/p/lucas_l594_type_flasher_lamp_single_contact) which have a glass which has a deeper dome, to make it more visible from side-on angles. When the indicators were fitted the sidelights were moved inboard. The same indicators would have been fitted at the rear.
I think the lights that excossack is describing are the earlier type of military lights (used on, amongst other things, Sankey narrow-track trailers) which have a metal "cup" with a coarse thread fixed to the vehicle, and a glass with four "ears" which screw into the cup. I believe that these are now quite hard to find, especially with the "ears" intact. These are the type shown in the upper photo on this page (http://www.sslawcorp.com/Military-Vehicle-Parts/screw-on-lenses-Military-Lucas-MOD/666383/). The original type of glass was later replaced in military service with the larger type shown in the lower photo on the same page, which fit the same base.
I doubt that your fire appliance would have had military pattern lights when built, unless it was originally suppled to the MOD. As mentioned before I think it was a civilian HD spec with HD cooling for stationary running, and as such is most likely to have had standard lighting for the era.
Post #911360 8th Jul 2021 10:40am
excossack
I have some of the glass screw in ones - two have one ear missing.
and I have the bigger/wider glass ones with the metal band/thread on the lense. 1999 Defender TD5 110
Regards
John M0VAZ
Post #911362 8th Jul 2021 10:45am
scotty38
England 2012 Defender 110 Puma 2.2 USW Aintree Green
I didn't click on Blackwolf's links but I bought my 488 and 594 lamps from Holdens too. If it's the same now I'd advise spending a bit more and get the ones with metal holders, far better than the cheaper plastic versions.
Post #911367 8th Jul 2021 10:59am
Shroppy
Great, thanks both! I'll order from Holdens if I can't find any original units. From the 'ring' in the paint around the sidelights it certainly looks as though a larger dia. fitting was previously used. 1985 127 V8 Build Thread
Series 2 109"
Series 1 80"
Post #911369 8th Jul 2021 11:08am
Gasket
I have a plain 109 hardtop and a pair of plain sides (I think the sides are plain, I'd have to go and look they're up at the storage unit). Just off the M6 at Warrington - drop me a PM if any good.
Post #911371 8th Jul 2021 11:17am
Trebro
United Kingdom 2009 Defender 130 Puma 2.4 HCPU Stornoway Grey
I have a 109 hardtop and cat flap, however the hardtop has period style sliding Windows, easy to change to solid panels on side
Drop me a pm if your still looking
Post #911722 10th Jul 2021 8:15am
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
There are a couple of 3 bolt tailgates on EBay currently or there was a couple of days ago.
Post #911747 10th Jul 2021 10:23am
strang
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Galway Green
Its worth scouring autojumbles for genuine lenses made from coloured glass. A lot of modern replacements are all clear glass which are coated with respective colour on the inner surface, but which will quickly fade, and look terrible. Euro-Leafing to infinity and beyond.....
Post #912057 12th Jul 2021 5:38pm
Shroppy
Thanks all, a good point there strang, I'll make sure to go to the next one at Malvern. 1985 127 V8 Build Thread
Series 2 109"
Series 1 80"
Post #912083 12th Jul 2021 7:54pm
Shroppy
It looks as though the L639 indicators are original fitment (only 2 mounting holes in the wing). So, if anyone has a spare lens and parts (body etc.) please let me know.
Series 2 109"
Series 1 80"
Post #912276 13th Jul 2021 10:35pm
