Home > Td5 > Td5 90 side sills - missing?
Vera's Driver
Hi All,
Removed rock sliders from my Defender 90 and fitted some steps. Bought satin black chequer plate sill protectors only to find that there is nothing to fit them too. This suggests to me , that when the rock sliders were fitted a sill of some description (with brackets/fittings) had previously been removed to accommodate the sliders. Can anyone confirm this is correct thinking and if so what part do I need to replace the void. Looked at parts companies but cannot make sense. Cheers in advance
Post #910745 4th Jul 2021 7:39pm
Sulisuli
Photos might help Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #910746 4th Jul 2021 7:50pm
landy andy
Yes you remove the side sill when you fit sliders to a Defender. About 50mm in depth, and are just pressed aluminium and held on with small m6 bolts.
Post #910748 4th Jul 2021 8:00pm
landy andy
Post #910750 4th Jul 2021 8:03pm
Vera's Driver
Thanks. Yep, from your link , bought the black bits (protectors) but do not have the silvery bits in situ to fit them too. Guessing these are brought separately which is what I need but lack the know how as to what to look up . Pictures on “part “ sites are not clear or particularly informative.
Post #910754 4th Jul 2021 8:29pm
landy andy
Post #910757 4th Jul 2021 8:44pm
landy andy
These are some of the part numbers.
RTC6206 & MTC8293
Post #910758 4th Jul 2021 8:48pm
Vera's Driver
Thumbs Up
Post #910761 4th Jul 2021 9:07pm
Moneypit
2004 Defender 110 300 Tdi HT Fuji White
Check out YRM 1 piece side sills, thicker & better quality and look factory once painted
Post #910766 5th Jul 2021 2:18am
