Home > Puma (Tdci) > Puma transmission/prop/UJ/Drivetrain issue
KeswickBen
United Kingdom 2009 Defender 110 Puma 2.4 SW Keswick Green
Hi all,
Having an issue with my Puma. Did a long 500 mile+ trip last weekend and on the return leg hearing all sorts of noises. Took it to the local 4x4 specialists and they can't figure it out. Car was serviced prior to the trip and no issues reported. Mainly a screeching noise when accelerating and low banging/grumbling noise coming from somewhere within the drivetrain. Screeching is worst when accelerating, and banging/grumbling most noticeable when decelerating under gear. All noises stop when pressing on the clutch.
Garage did a full inspection and found no issues on the props and UJs, which were my first suspects. Also couldn't pinpoint the issue with a digital audio inspection and have referred me to a transmission/gearbox specialist. Having a look under myself, checking the props with handbrake on/off - front prop, rear UJ (see pic) has a lot more play in it compared to the other three. Also noticed a small amount of oil on the transfer box assembly/extension.
Any help would be greatly appreciated! Cheers!
Post #910707 4th Jul 2021 1:45pm
Retroanaconda
There should be no play at all in the UJs - if there is then they need replacing ASAP. Failure while driving is liable to cause lots of damage.
Post #910708 4th Jul 2021 1:49pm
KeswickBen
Cheers, fully aware and my thoughts exactly ref the UJs. So why did the garage give them the all clear?!
Post #910712 4th Jul 2021 2:02pm
Pacha
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
Some 'specialists' are very much not. Rgds.
Chris
Post #910714 4th Jul 2021 2:09pm
landy andy
If the garage you took it to for the service and the diagnostics is the same one. Don’t bother and never return to them. Those UJ’s haven’t been greased for many a mile from what I can see. So they didn’t service it properly, or diagnose it
Even if you just pump some grease in a take it for a quick drive you tend to hear a change in noise and feel.
Post #910716 4th Jul 2021 2:14pm
Yep, UJ’s need replacing immediately, wouldn’t recommend you drive it at all either until done.
As mentioned they are dry and haven’t been lubed, and looks to me that there is at least one set of roller bearings in the cup gone there that I can see and the seal gone too.
I had very similar, never picked up on MoT either, at least you found it I had a lot of trouble finding it with mine.
GKN UJ’s are best, unless you want to spend more and go genuine which are likely to be the same too. Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #910727 4th Jul 2021 4:58pm
