Home > Maintenance & Modifications > Wiring in DRL so they come on with ignition??
Jgould1990
Hi guys looking for some help have a 2015 90 with LED headlights but the DRLs aren’t wired in and I wanted them to come on when I turn the ignition on not just the side lights?? Just seeing if anyone has done this or would know how to? And would be willing to help??
Thanks
Post #910644 3rd Jul 2021 7:19pm
Notyalc
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
Plenty of magic boxe s about.
Powerfuluk do one that links to the side lights as well.
Post #910649 3rd Jul 2021 7:45pm
spudfan
Ireland
I have DRL'S on a 2.4 Puma. They come on when the ignition is on. As I have a connection to the side light they go off when the lights come on. As they do not dip they would blind on coming traffic at night. If you want them on all of the time don't connect them to the side light. Mine are Ring Aurora. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #910667 3rd Jul 2021 10:19pm
llessur
If you fancy wiring them up yourself, here is the relay wiring.
ignition only= drl on
ignition+ side light = drl off
Post #910680 4th Jul 2021 6:22am
Mo Murphy
And use a normally closed relay 😉
50 Shades of Pennine Grey
Post #910685 4th Jul 2021 8:15am
Dinnu
87a is the normally closed side of the relay contacts.
87 is the normally open side of the relay contacts.
You may find relays that only have 87a or only 87.. in that case make sure it has the 87a. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #910689 4th Jul 2021 9:12am
