![]() | Home > Td5 > Not starting - is the alternator gone? |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2967 ![]() ![]() |
Sounds like starter motor 🤔
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17996 ![]() ![]() ![]() |
It sounds to me as though something at the front of the engine has seized, it could be any of the things driven by the serpentine belt, or one of the idler pulleys. The clunk may well be the starter failing to turn what is, in effect, a seized engine.
I suggest removing the fan, taking the belt off, and seeing which if any of the pulleys no longer turns. |
Gandhi the Landi Member Since: 17 Mar 2021 Location: Meath Posts: 6 ![]() ![]() ![]() |
Thanks for the reply. Would the starter motor have been making a noise while the motor was running, prior to the complete stop. It definitely was running and something went and engine stopped.
Thanks |
Thanks blackwolf. Will give it a go!!!
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6030 ![]() ![]() |
Get a spanner on the front of the engine and see if you can turn engine by hand. Does sound very odd.
