![]() | Home > Puma (Tdci) > Bonnet stolen again. |
Mick Clark Member Since: 20 Dec 2009 Location: Hertfordshire Posts: 75 ![]() ![]() ![]() |
There have been some good ideas regarding cable locks and cables to secure the bonnet to the bulkhead etc but if they can snip your battery earth cable then cables to bulkhead are only another snip, snip away. I'm thinking that the best way is to prevent the bonnet being opened in the first place which I'm afraid comes down to the good old padlock and hasp which if you have an A Bar would be hidden from general view. I just think that once they have the bonnet open and then realise it can't be lifted off they might cause other expensive damage out of spite.
I have thought about fitting a sensor to the driver's door as part of the home alarm system but realised that if the alarm is on stanby and you return home the alarm would be set off as soon as you open the driver's door. For about £140 you can buy a home wireless alarm kit just for the car and fit sensors to the bonnet and doors. That way if anyone tampers with the car you and your neighbours will soon know about it. These systems can also send you a text if the alarm is set off. Expensive I know but just a thought. Mick |
![]() Click image to enlarge ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() ![]() IID Pro MV License |
Gil9713 Member Since: 11 Sep 2011 Location: Colchester Posts: 94 ![]() ![]() |
dgardel,
Nice pics of your newly painted hinges, how does that stop the bonnet being lifted off once in the vertical position, unless the nut and bolt do something magic in holding an open clip body hinge together. The problem I see with that is its quite expensive, and I take it the same manufacturers haven't looked at the front end at all then? |
Same ones I posted up but in black....Still look ![]() ![]() ![]() ![]() Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 25th Sep 2011 8:10am. Edited 1 time in total |
GIL9713
Yes you are right, anything that delays them means there is more chance they will give up and as you say the stickers should warn them that its not going to be easy. Mick |
Constantin_Valdor Member Since: 28 Sep 2012 Location: Cheshire Posts: 13 ![]() ![]() ![]() |
Hi, all this talk of bonnet theft has got me worried as I only got my 90 yesterday evening...! done some searching around, has anybody used/experience of these?? -->
http://www.mudstuff.co.uk/Defender_Bonnet_...nges.shtml "Innocence proves nothing, as there is no such thing as innocence, only degress of guilt" |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584 ![]() ![]() |
We don't keep stock of those but can get them if need be. We stock the off-road tec ones and we should be getting stock of the entreq ones shortly.
There are two threads on these hinges in the 4x4overlander sponsors sub forum. We have the black offroad tec ones fitted to ours. If you would like some advice on the different hinges just give Brendan a ring. Regards Barbara |
To the best of my knowledge there are three makes of security hinges for Defender bonnets.
The GMB one which Mudstuff stocks. Then there is the Offroad Tec which was a group buy on Defender2 and which we now stock. ![]() Then there is Entreq version which we are waiting on supplies. ![]() Click image to enlarge Anything which delays the scum bags the better. Off the three hinge available I believe the Entreq one will take greatest time to over come. As for the looks of the hinges I will leave that up to individuals to decide Theft of a Puma bonnet has been caught on CCTV and lets say it was a slick quick operation. Brendan Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
SteveS Member Since: 05 Oct 2010 Location: Devon & Berkshire Posts: 388 ![]() ![]() ![]() |
Brendan - the OffRoad Tec ones look nicest of the bunch in the photos. Can you explain what a thief would need to do to take the bonnet off? Is it as simple as undoing those 3 bolts, or taking out the hinge bolt?
I suppose you could hammer the threads over to stop things being unbolted. Using a cycle cable lock on mine at present |
Putting it bluntly there is no ease simple way to make things like Puma bonnets thief proof.
Theft of a standard bonnet by people who have practised it is a slick quick operation. The cost of replacing a Puma/TD4 bonnet could be around the £1,000 by the time you have bought a genuine replacement bonnet, bonnet release mechanism, decal, respray job etc. All the security hinges do is buy you time. The longer it takes the scumbags to remove your bonnet, the more likely they are going to move on and nick somebody else's bonnet. If they come with the right equipment then yes it would still be possible to nick a puma bonnet. Hopefully they will 'case' the bonnet first and decide if it is fitted with security hinges then hopefully they will move on. I hear too many stories of burglars not being able to actually steal computers so have just smashed them. Removing the bonnet can make life easier when it comes to working on the engine so that more 'permanent' ways of securing bonnet may not be desireable. Having seen the GMB hinge, fitted the Offroad Tec hinge and seen the CAD drawings of the Entreq hinges I think the Entreq hinges would take the longest time to remove. Please remember that these type of hinges are relatively new so the less information for the scumbags can pick up the better. Brendan |
after having looked at various photos and description on the web from the hinge suppliers - I assume even thieves can read - it seems fair to say that with the bonnet lifted then the weak link is the 3 bolts. Whilst it will stop the grab and run type of thief and delay for a few minutes the ones that have disabled the alarm (or can live with the racket) it won't stop the ones that have a bit more time - ie 5 minutes. Restricting the bonnet opening range (or maybe keeping it padlocked shut) will provide further hassle.
I know a determined thief will eventually get what he wants. However, I'm wondering whether anyone has had some thoughts on an electrically energised dead-bolt system, operated by hidden internal switch (energise to open) to operate alongside the cable operated latch? |
The nuts on the inside of the bonnet could be replaced with security nuts. Any would be thief with the Entreq fittings would need a good supply of security tools with them.
Brendan |
Just put of interest, why's that Brendan? From the pictures the Offroad Tec and Entreq look virtually identical. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
