Home > Maintenance & Modifications > Stage 1 V8 grille on TD5 defender
nadg201
After falling in love with the look of a stage 1 grille on a defender 90 and succeeding in the hunt to find a original grille I now have the dilemma I should have thought of first. How easy is it to fit one to a TD5 defender?
From photos it looks like it should be an easy screw in job, however I’ve fallen for that mistake before. Any help and advice would be appreciated.
Post #910155 30th Jun 2021 1:53pm
It's an easy and direct fit to a non-AC vehicle (don't know about the AC grille), but does leave the six holes from the original grille which will need filling.
The hardest part is finding a Stage 1 V8 grille, they are a bit like the proverbial rocking horse poo! The only source I know of is Pegasus Parts, and they're not cheap for a chunk of wire mesh.
Post #910161 30th Jun 2021 2:59pm
Very easy - it's a simple nut and bolt task. However, if your heart is set on a genuine Stage 1 grill then they're like hen's teeth and if you can find one, very expensive. Assuming though that you're talking about a modern equivalent such as that from Lockswood International or Zunsport, then they come as a kit with all of the necessary fixings.
There are a couple of 'gotchas' to be aware of. Firstly, you will be left with the fixing holes in the surround for the original grill. The kits usually come with suitable fir tree type fixings to blank these off but some folks have the holes filled and the surround painted to lose them completely. Secondly, fitting to a non-air con model without the protruding grill surround is a something of a challenge as these types of grills are fitted from the rear but the panel can't be easily re-fitted with the grill in place. It's not impossible but can be difficult, particularly if you have a steering guard or large winch bumper fitted, for instance.
Whilst it's changed a lot since, here's mine from a couple of years ago:
More details of the install process here: https://www.defender2.net/forum/post738660.html#738660 Darren
Post #910162 30th Jun 2021 3:06pm
LandRoverAnorak wrote:
... fitting to a non-air con model without the protruding grill surround is a something of a challenge as these types of grills are fitted from the rear but the panel can't be easily re-fitted with the grill in place. ...
I imagine that this comment refers specifically to the modern "look-alike" grilles you mention, since the Stage 1 V8 grill fits from the front and does not require removal of the surround. In essence there is no significant difference between the V8 grille surround panel and the non-AC Defender panel apart from the six holes the later panel gained, and the deletion of the bonnet lock.
One concern with the genuine V8 grille is actually the ease with which it can be removed - having a grille worth well in excess of £100 held on by two screws is a little worrying in this lawless age.
Post #910164 30th Jun 2021 3:41pm
Yes, exactly that although I've just realised that I missed an important detail in the OP in that he's already got an original grill Rolling Eyes Darren
Post #910165 30th Jun 2021 3:52pm
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
Here’s mine.
Post #910197 30th Jun 2021 7:25pm
gcc130
I’ve gone for the stage 1 look on my Puma Dormobile (not quite finished yet)
Post #910201 30th Jun 2021 7:38pm
90 Dreamer
A "filled" & painted version on mine.......
Post #910202 30th Jun 2021 7:49pm
nadg201
Quick update, unfortunately I ended up getting scammed on a Facebook forum and the grille is no longer on the way. Instead a man going by the name of Jason Todd from the Isle of Man has run off with my money. Looks like the modern version may be the solution once I save up the money I lost.
Post #910676 4th Jul 2021 12:35am
Mo Murphy
I have a nice Stage 1 type grille that I had made for me in stainless steel as I thought I'd like the look. I didn't !
So if anyone would like it, fitted once for trial, £60 posted. Pm me.
50 Shades of Pennine Grey
Post #910686 4th Jul 2021 8:22am
ibexman
You have PM
Post #910687 4th Jul 2021 8:49am
