![]() | Home > Td5 > Mantec Plastic Jobby or Safari raised intake? |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4331 ![]() ![]() ![]() |
You don’t get any extra wading ability from a snorkel without altering the intake pipe work and air-box. They are leaky as hell. 2007 110 TDCi Station Wagon XS
I took my Safari one off as it kept filling up with water as it never seals that well to the wing that well and the pipe work was that easy to seal and was a pain to keep seated.
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17936 ![]() ![]() ![]() |
An alternative to Mantec or Safari, which are adequate (just) as RAIs, would be to fit a good one such as Nakatanenga. This will generally also replace the woefully inadequate, restrictive, and leaky inlet duct and leaves only the airbox to seal. More expensive, undoubtedly, but better value overall.
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 992 ![]() ![]() ![]() |
I have had the OEM Mantec on mine from the factory, going on 21 years now. It can easily be sealed up and I regularly use it in water over the bonnet. It is quite robust in spite of it looking flimsy
![]() ![]() Click image to enlarge 2020 range Rover Mk IV Autobiography PHEV 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
