Home > General & Technical (L663) > L663 110 distance between roofbars
carrotbay
United Kingdom 2008 Defender 110 BMW M57 3.0 Diesel XS CSW Auto Santorini Black
Hi
Does anyone have roofbars on their 110 L663? If so please can you post the distance between the mounting rails in the roofbars of the front and back bar.
Thanks
Phil. 2008 Defender 110 XS SW - M57N2 / 8HP70X
Post #909081 23rd Jun 2021 11:12am
carrotbay
Even the distance between the midpoint of the little locking cutouts on the roof rails rather roof bars would do. Just trying to see whether my existing bike rack is going to work or not.
Thanks 2008 Defender 110 XS SW - M57N2 / 8HP70X
Post #909147 23rd Jun 2021 5:06pm
Tim in Scotland
I took my crossbars off a couple of weeks ago but there are several options for fitting them - shorter distance between them or longer distance between them…… you might have to enlarge this photo too see the three mounting slots.
Here’s a picture with them in the front and middle mounting slots when I had them on the car
Which positions do you need the dimensions for? Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
Post #909190 23rd Jun 2021 8:21pm
carrotbay
Hi Tim
Thanks for your reply. I thought there was only one configuration for the roofbars based on the 2 smaller cutouts on the inside edge of the roof rails. I picked that up from this link section 10 .. http://accessories-instructions.landrover....r/G2409809
If you could measure the roof rails between the midpoint of the smaller cutouts on the inside edge of the roof rails that would give me the answer and be really helpful .. thanks for your help on this.
Regards
Phil 2008 Defender 110 XS SW - M57N2 / 8HP70X
Post #909216 23rd Jun 2021 10:35pm
Having fixed points for the cross bars seems really odd as I'd have thought the whole point of the roof rails that the bars can be fitted anywhere along their length, if the width is suitably adjusted. That's certainly the way they work on a Discovery and RRS. Darren
Post #909225 24th Jun 2021 5:53am
carrotbay
That’s exactly what I thought, but the fitting instructions indicate they have only one fixed place, same with this video ..
A bit disappointing as depending on the load you might want to spread them out a bit. I want to use my existing 2 part cycle rack (fork mount and wheel mount) so the distance between the bars is pretty important for this to work. 2008 Defender 110 XS SW - M57N2 / 8HP70X
Post #909227 24th Jun 2021 6:31am
Tim in Scotland
Centre to centre of the small cut outs is 700mm, also my apologies, there is only one mounting position as there is no small cutout behind the rearmost slot
Post #909244 24th Jun 2021 8:35am
carrotbay
Hi Tim .. that’s great, thank you very much for your help.
Regards
Post #909247 24th Jun 2021 8:40am
Andiamo
United States
I suppose if you get the ones optioned at the dealer you’re locked into just a few locations for the roof bars. I just ordered the parts from Thule myself. I like the look of mine better as well plus I can place the bars at any location along the tracks.
Post #909409 25th Jun 2021 11:58am
carrotbay
That’s not a bad idea .. please can you share the parts you used? 2008 Defender 110 XS SW - M57N2 / 8HP70X
Post #909415 25th Jun 2021 12:18pm
Andiamo
United States
These are the parts I ordered:
Thule 3040 Fit Kit
Thule 753 Rapid System Foot Pack
Thule Wingbar Evo 127 (50 in)
Found the idea in this thread: https://www.defender2.net/forum/topic74903.html
Post #909543 26th Jun 2021 12:10pm
carrotbay
That’s great .. thank you 2008 Defender 110 XS SW - M57N2 / 8HP70X
Post #909559 26th Jun 2021 2:11pm
