![]() | Home > Technical > Indicator relay stays solid randomly |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6684 ![]() ![]() ![]() |
Standard indicators and factory flasher unit or LEDs and/or aftermarket flasher?
Matt110 Member Since: 29 Jun 2014 Location: UK Posts: 687 ![]() ![]() |
All standard
Both sides a problem?
If so I would swap out the flasher relay with another as a first step. ![]() ![]() |
Yep, both sides exactly the same. It's like it's lost its capability of flashing but "indicates" left, and right, and hazards, all correctly and with lamps lit, but not flashing.
Will swap it out and see what happens. Cheers Martin. ![]() |
