![]() | Home > For Sale & Wanted > [SOLD] SOLD Alive Tuning Interface Console (ATRIC)- As New |
| moresauce Member Since: 18 Feb 2012 Location: UK Posts: 50
NOW SOLD
I'm selling an unused and as new Alive Tuning Interface Console also know as ATRIC. Boxed is marked and damaged from storage but otherwise this is unused and as new. This is the hardware only and does not include any remap. Can also be used to read fault codes etc New this costs £195 and can be seen HERE I'm asking £100 including postage Alive describe the ATRIC as follows: The Alive Tuning Remap Interface Console (ATRIC) lets you reprogram your Land Rover Engine Management anytime, anywhere, by simply plugging into your car’s ODB2 socket. With its 256Mb of internal storage, ATRIC p3 can hold up to five states of tune, with a backup of the original vehicle software, so you can return the car back to standard, anytime within just a few minutes. The latest 32bit archetecture means the ATRIC p3 is lightening fast in operation, reading and writing maps around 4x faster than the previous generation of ATRIC. The full colour touch screen provides an intuitive step-by-step walkthrough, that gives you the confidence and security you need to quickly and reliably apply ALIVE remapping to your car’s ECU. Tuning files are created individually according to customer specific requirements, vehicle spec, usage and climate. ATRIC p3 will take a snapshot of your vehicles orginal ECU calibration and store it in its memory. Using the ATRIC p3 PC software, this original file should be emailed to us for modification, where we will tailor your remap to suit your precise needs. The interface not only allows you to tune your ecu, it also acts as a generic Fault Code reader, allowing you to Read and Clear engine management fault codes. Please note that the fault code functions do not work on the Td5. ATRIC p3 supports the following Land Rover models, and also a wide range of European cars and vans: (Vehicles marked with * will be supported on the next update). Defender Td5 Defender 2.4TDCi Puma Defender 2.2 TDCi Puma** (Requires OBD unlock) Evoque 2.2 TD4 Evoque 2.2 SD4 *Evoque Si4 Freelander 2.0 TD4 Freelander 2 2.2 TD4 Freelander 2 2.2 SD4 Discovery Td5 Discovery 3 2.7 TDV6 Discovery 3 4.0 V6 Discovery 3 4.4 V8 *Discovery 4 2.7 TDV6 *Discovery Sport 2.2 SD4 Range Rover Sport 2.7 TDV6 Range Rover Sport 3.6 TDV8 *Range Rover Sport 4.4 V8 *Range Rover Sport 4.2 Supercharged Range Rover 3.0 TD6 Range Rover 3.6 TDV8 *Range Rover 4.4 V8 *Range Rover 4.2 Supercharged *Range Rover 5.0 V8 *Range Rover 5.0 Supercharged Please note that ATRIC p3 software is for Windows PC only. Last edited by moresauce on 18th Jun 2021 3:53pm. Edited 1 time in total |
Now sold
Thanks |
| All times are GMT |
