Home > Technical > Td5 running issues.
TVR Tommy
United Kingdom 2000 Defender 90 Td5 Heritage LE Bronze Green
Td5 running issues.
I get some strange intermittent running issues with my td5 p15. Coming down the motorway today horrible wet conditions my defender starts surging. It pretty much goes away any constant throttle but the more throttle you give it the longer the surges. You can keep a cruise at 60 with a bit more throttle than normal.
Pulled on to the hard shoulder and restarted to see if it cleared the issue. Nope when building speed it was surging again. I have a compushift display so can see throttle and boost %’s throttle stable and boost up and down not surprisingly. Got back to cruising speed car behaves normal. 1 Mile down motorway it back to being ok no surging under acceleration.
It down it before and the surging only manifests itself on the motorway.
Another issue that I’m not 100% sure isn’t in my head is that I feel I loose throttle response some days on my commute so normal cruise along at 60 at 45% throttle. Then the throttle responses becomes sluggish and I’d need 55-60% to keep cruising speed. As quick restart and I feels like it’s back to normal. I’ve try logging data on my nanocom when I feel it gets sluggish and all seems fine no strange readings
Typically I never have the nanocom in the car when the more extreme surging starts so have no logs for that. As I’m sure that would show something up. The surging on motorway probably happens once a year but I don’t do a whole lot of motorway driving. My td5 is running a alive stage 1 map but I do have the original standard mapped ecu which I’m going to put back In once home. I do wonder if my fuel pump is starting to play up. But it never fails to start hot or cold and with a short crank.
Sorry if some of this doesn’t make sense just typing out on my phone whilst fresh in my head.
Any pointer much welcomed. .
Post #908406 18th Jun 2021 10:45am
Hufflepuff
I had something similar a couple of years ago, in very heavy rain and sprary on the motorway.
It was like the throttle pedal was going off - on - off - on, and I prepared myself to break down. Fortunately it cleared and hasn't happened since.
I did find the paper filter element had all stuck together, so presumably water got sucked through the intake, but why that would cause those symptoms I am not sure. 2005 Td5 90 XS
1989 V8 110 CSW
Post #908409 18th Jun 2021 10:58am
landy andy
Is the turbo wastegate moving freely?
Post #908411 18th Jun 2021 11:05am
rallysteve
Do you have a RAI? Possibly the filter getting wet (as above) 02' 110 TD5 Double Cab Rebuild Thread
Post #908412 18th Jun 2021 11:07am
TVR Tommy
Waste gate is fine and it doesn’t feel harsh enough to be overboost
Standard air intake. And I don’t think it’s water being sucked in. I don’t remember it rainIng the previous time it did the surging.
Just wish I had the nanocom in there to do a log. As I think it would have narrowed things down.
Post #908515 19th Jun 2021 9:18am
barbel jim
Have you checked the air filter anyways? Standard intake or raised they still suck in water in heavy enough spray. Foam filters tend to be more forgiving than the OEM paper type.
Post #908565 19th Jun 2021 8:56pm
barbel jim
Also worth checking the fuel pump relay
Post #908566 19th Jun 2021 8:57pm
TVR Tommy
I'll check the fuel relay.
Had no issues on the return journey. I really do think I have a underlying running issue. I'm going to swap out the alive Stage 1 ECU tonight.
Post #908702 21st Jun 2021 8:01am
