![]() | Home > Puma (Tdci) > Steering issues |
| 110 Iain Member Since: 11 Nov 2019 Location: Scotland Posts: 93
Hi all just changed drag link and track rod plus steering damper set all to recomended lengths centered steering then adjusted drag linkto set
Steering straight went for test drive she steers straight but steering now feels stiff and has poorer return to centre its hard to judge as there waa fair bit of play before as all ball joints were shot don't want to adjust steering box as was OK before have I missed somethingalso noticed lock to Lock is two fuul turns one way one and a half other way is this normal any advice appreciated Endeavour To Persevere |
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8488
This could also be why return to centre is out but I don't think so. Once done above and sorted the centre run it without damper and see what return to centre is like. You haven't changed suspension or done any swivel work at the same time have you. Cheers
Thanks for reply no other work done to centre steering I just kept drag ling of at box end then turned steering full lock left then 2 turns back
Then adjusted drak link to fit wheels all in line is that the correct way? Endeavour To Persevere |
No, correct way is as above, 2 turns is not centre of box. Cheers
So started again drag link of alligned steering box with bolt on hole adjusted drag link to suit then just halfturn to set wheels even steering wheel was centre but steering feels heavier than before with little return to centre if I turn left and release steering wheel it holds position not as bad at
Higher speed can't see whare I might have gone wrong have removed new damper it was an all make one will test drive to see if improved Endeavour To Persevere |
| All times are GMT |
