![]() | Home > Expedition & Overland > who offers 3 inch raised air intakes |
Moneypit Member Since: 27 Feb 2018 Location: North Yorkshire Posts: 271 ![]() ![]() |
I think Performance & Protection in UK do a 3" pipe, I was after one a while back, but from memory it is a ridiculous amount for a bent piece of steel pipe. £300+ & you don't even get an intake top
LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11325 ![]() ![]() |
The offering from Nakatanenga is a nice piece of kit, albeit at a price. You may need to adapt the length of the hose under the bonnet though, as I can't remember where the air filter box is on a 300tdi.
![]() Click image to enlarge More details of the installation here: https://www.defender2.net/forum/post820692.html#820692 Whilst I appreciate that it's a completely different engine, it's made a world of difference to the pickup and driveability of my 2.2tdci. I don't know where it would be easiest for you to buy from but mine came from their UK distributor: https://www.4x4overlander.com/product/defe...ender-td4/ Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
jimbo55 Member Since: 15 Jul 2020 Location: Midlands Posts: 404 ![]() ![]() |
P&P do one, works really well, especially if you have a roll cage fitted but it’s not cheap
Works with either a safari top or a Donaldson prefilter ![]() Click image to enlarge |
overlandbyrover Member Since: 16 Jun 2021 Location: Charlotte Posts: 8 ![]() ![]() ![]() |
thank you all. looks like all roads lead to only a few products. I see the Nakatanenga snorkels are listed as 80mm. can someone confirm the ID? Nakatanenga doesn't list product brand for their snorkels, so I can't tell what's their own product versus others.
Nakatanenga's snorkels are their own make. The tubes are powder coated aluminium so the ID is probably 77-78mm. Darren
well there it is! thanks!
Matt110 Member Since: 29 Jun 2014 Location: UK Posts: 687 ![]() ![]() |
That looks great Jimbo - is it on a PP cage or an SD one? |
Another one for PandP cages RAI here. Mine is attached to a SD roll cage and works a treat. Replaced the scoop for a cyclonic top as the scoop didn't filter out enough of the rain we get here in Wales
![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
Cheers Matt, it’s a P&P internal and external cage -external front hoop with internal b hoop with a cross in it and diagonal back stays. |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2214 ![]() ![]() ![]() |
Can always make one from exhaust sections. If you cant weld, buy they bits and have it done.
Do love your 110.
What did you do on the inside once you'd made it through the wing? |
Thanks!
![]() Should have mentioned mines actually 3.5" ![]() Click image to enlarge ![]() Click image to enlarge 3.5" wire reinforced flexi pipe, then runs off to a Wrecker Fab airbox with an ITG 300tdi filter. 3" outlet from the filter to the turbo. |
Timcat Member Since: 20 Jul 2016 Location: Rugby at the moment Posts: 1025 ![]() ![]() ![]() |
Is the last photo the Wayfarer? |
The one and only ![]() |
