Home > Puma (Tdci) > Intermittent "won't rev" Problem
AndyS
Hello,
I had a problem with the clutch switch (revs were hanging on gear change) so I changed it and the problem went away. About two weeks on and I have another intermittent problem that's getting worse, it suddenly won't rev past about 2500 rpm. This morning I had a new development where it just wouldn't rev, foot flat to the floor and it sat at tick over and that was it. Anti-stall still worked so I was able to limp it to the side of the road and shut it down. On restart it ran fine for a while before the rev-limit problem came back. That then cleared and I drove home. It's now too bad to drive more than around the block so I need your help!
Things I've already tried:
  • Cleaned the sensor just after the airbox but it looked clean anyway.
  • Cleaned the sensor just before the inlet manifold, it was caked in crap which isn't a surprise as I had a injector seal leak last year and the engine was recycling loads of crap. Sensor cleaned and it runs a lot better during the good phase but hasn't stopped the rev-limit phase.
  • Cleaned all the injector connections but that all looked OK.
  • WD40'd and air-lined the throttle pedal potentiometer(?) but it looks like a sealed unit so no maintenance to be done.
  • I've refitted the old clutch switch to the loom but not to the clutch cylinder just to see what happens and the anti-stall problem returned (where the revs hang on gear change) but the rev-limit problem was also still there. I think that means it's not the clutch switch?
  • Had a look around for other totally obvious issues but can't see anything.
Because it runs OK for some of the time I'm pretty sure it's a sensor problem but there are no warning lights. Do you need to reset any error messages when changing the clutch switch because it seems to have got a lot worse since then. Any suggestions are greatly received.
(Just by way of a semi-rant the car has been totally brilliant for most of the ten years we've had it, it got us to the hospital recently when a relative was in the final stages of life, got us home when it was pissing oil all over the place and got my two dogs to the vets when they were in need of urgent, life saving care. But it's picked it's moment on this one, we're totally out of money! But I still love it.)
Post #908132 16th Jun 2021 12:47pm
AndyS wrote:
... it just wouldn't rev, foot flat to the floor and it sat at tick over and that was it
Usually known as "limp mode". There are many things that can cause this, have you checked to see what stored DTCs you have? They should point you to the problem.
Mine did this when the hose from the turbo to the intercooler failed after chafing through on the lower steering joint, no MIL, but limp mode with a large trailer wasn't fun.
Post #908169 16th Jun 2021 4:39pm
AndyS
Is that limp mode! Well it's no fun at all. I haven't got a diagnostic tool so don't know what it's trying to tell me. It could be a hose, I've had the inlet (from intercooler to inlet manifold) fail so they must all be getting to that stage where they split. I'll check later when the weather has cooled off.
Thanks. Thumbs Up
Post #908179 16th Jun 2021 5:36pm
jst
Can you source another throttle assembly to try? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #908242 16th Jun 2021 10:28pm
AndyS
jst, no. All I have is hammers and tape. Very Happy
It's peeing down with rain so no work on the car today, I'll draw up a list of things to check for tomorrow. I really dislike those star allen key type bolts, they're just annoying (as I haven't got tools for them).
Post #908276 17th Jun 2021 9:30am
boxoftricks
United Kingdom 2011 Defender 110 Puma 2.4 USW Zermatt Silver
There seems to be a theme across the forum that people fix one problem and it creates another. As Blackwolf says check your pipes do not come loose or have cracked when they were disturbed.
Grab a diagnostic tool or pop by your local garage. Most love Defenders enough to give you a free diagnostic reading. Without that, you're in danger of just randomly replacing parts hoping to solve the issue.
Good luck
Post #908292 17th Jun 2021 11:55am
AndyS
I think you're totally right, I've just read the Nanocom manual and the likelihood of randomly getting the right sensor out of all the sensors and readings it's taking is extremely small. I'll have a chat with my local mechanic in the morning.
Post #908354 17th Jun 2021 7:35pm
jst
I concur get the faults read, you have done most things you can do. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #908356 17th Jun 2021 7:58pm
AndyS
The only fault was Glow Plug Relay. I'm just reading about it, it can actually cause limp mode to activate (according to the transit people). I'll read some more and order one, they're not much money so worth a try. I've had a prod around the lower turbo hose and it's as flimsy as heck but I can't find an obvious split. Mechanic said to take it off and actually look at it, if I'm going to do that I'll order a new one to put back.
I'm sure it can't be this easy but fingers crossed!
Thanks people. Thumbs Up
Post #908428 18th Jun 2021 1:15pm
jst
would be interested to hear the outcome Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #908459 18th Jun 2021 6:26pm
Change the VCV unless you already have? ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #908472 18th Jun 2021 8:10pm
AndyS
I haven't and I've just read a nine page thread about them, it certainly sounds like that could be the problem. Better order one of them too.
Post #908494 18th Jun 2021 10:59pm
Thumbs Up I reduction in power in 6th is a key give away as is a rough idle when stone cold in winter.
The reduction in power is minimal over time and hardly noticeable though.
If it is that, when the VCV is changed you’ll notice a definite increase in availed power across all gears especially higher end.
Mine started out like how yours is then moved on many months later to randomly cutting out when cold.
I had it once pulling out onto a 50mph round then a quarter mile down same road at a roundabout.
At that point I went straight home, knew it’s not safe to drive it got a new VCV and it was sorted.
Failed clutch switch tends to give a power surge once into gear and odd behaviour during gear changes.
VCV tends to be power related, I think mine was finished off with som emojis true in some fuel I got once from a certain fuel station I won’t use again. Rolling Eyes
PF Jones is the place to go, they aren’t expensive or difficult to change.
Mine came in a genuine Nissan parts box as it’s fairly generic, been great since really powerful. Shocked
Over a period of time you don’t notice until it’s put back. Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #908559 19th Jun 2021 7:42pm
AndyS
Morning, first stupid question of the day (Haynes manual is especially useless on this), is that the VCV valve, just next to the high pressure fuel pipe and below the inlet manifold? I've undone the bolts and suddenly panicked that I don't even know if I'm undoing the right thing.
Post #908609 20th Jun 2021 10:40am
AndyS
Ok, ignore that. The new part has arrived so I can compare. Stay tuned for more daft questions!
Post #908611 20th Jun 2021 10:52am
