![]() | Home > In Car Electronics (L663) > Locking the car on a ferry |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2762 ![]() ![]() |
Yes, you can disable sensors for the next ignition cycle. You’ll also need to put the tracker into transport mode if you have that set up.
Can't find anything in the iguide
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3493 ![]() ![]() |
I’m sure its in SETTINGS - VEHICLE, transport mode is in settings on the app 24MY 90 D250 HSE, Tasman Blue
I cant see any options in the app. I think its just a case of single press of key fob to lock doors only. 130's have feeling's as well you know
For the alarm you don’t do it on the app, it’s in the pivi pro settings menu, under the Vehicle category as above. Basically you drive onto the ferry, apply the settings in the menu and then the sensors are disabled for one ignition cycle.
You put the tracker into transport mode using the InControl app, it disables the movement alerts for a period of time. |
Service and Transport modes are in MORE - VEHICLE SETTINGS
![]() ![]() Click image to enlarge 24MY 90 D250 HSE, Tasman Blue |
