![]() | Home > Maintenance & Modifications > Paint for rear cross member? |
When I did mine in May last year, I went the fairly traditional route of etch primer, regular primer, satin black and clear lacquer, which is holding up very well so far. I don't think you need anything exotic if the preparation is good.
![]() Click image to enlarge More details here: https://www.defender2.net/forum/post829009.html#829009 Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
jim4244 Member Since: 13 Apr 2014 Location: Bedfordshire Posts: 983 ![]() ![]() ![]() |
Hmmmm……. That was my first plan. I was just thinking that the waxoyl looked good and filled in various dents but the black gunk that ended up on your hands and trousers was such a pain.
What about Ditrinol? Does that dry so that there is no black gunk transfer? Jim |
I think it's less sticky than waxoil but still doesn't dry, as such. It looks ok underneath but I wouldn't consider it for a visible area like this. Darren
He are my before steam cleaning and after photos.
![]() Click image to enlarge ![]() Click image to enlarge |
I suppose that the look I’m after is something similar to black powder coating, but from a spray can.
Does that make sense? 😂 Jim |
jpboost Member Since: 13 Apr 2021 Location: Gatwick Posts: 378 ![]() ![]() ![]() |
That makes sense. I'd have thought most satin finish blacks would do what you need. The only think I'd check is that some chassis black paints are not UV stable and discolour in direct sunlight.
I used a paint from buzzweld on my last one and it's lasting really well. I can't remember exactly which one it was, but it was brushable and easy to use. As above, preparation is key to getting a good final result. |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1750 ![]() |
![]() Click image to enlarge Buzzweld - Chassis In One CIO https://www.buzzweld.co.uk/chassis-paint-b...n-one.html |
boxoftricks Member Since: 06 Feb 2019 Location: Home Counties Posts: 751 ![]() ![]() ![]() |
Same issue, makes a mess. |
Thanks everyone 👍
I have just ordered buzzweld CIO which looks like it will give the finish I’m looking for. Jim |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3748 ![]() ![]() ![]() |
Buzzweld again here.
Litch Member Since: 10 Mar 2013 Location: Oxfordshire Posts: 767 ![]() ![]() |
My chassis is black Waxoyled but the face of the rear crossmember is just painted in Frosts Extreme Chassis Black (Satin).
Lovely finish and very hard wearing. ONE LIFE, GET IT! |
athelstan Member Since: 06 Aug 2019 Location: Kent Posts: 55 ![]() ![]() ![]() |
I didn't want all the faff of spray painting,masking and priming so I opted for E-Tech Chassis Paint. Just lightly sand to get a key, degrease and paint with a brush. You would have to be very close to see any brush marks and it dries to a semi matt finish. The actual finish dries to be as hard as porcelain. 2015 90 XS Station Wagon Puma 2.2
2015 Morgan Plus 4 |
![]() Click image to enlarge 2015 90 XS Station Wagon Puma 2.2 2015 Morgan Plus 4 |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4316 ![]() ![]() ![]() |
Dinitrol definetly stays tacky, my chassis is Sahara sand yellow with all the Moroccan dust stuck to it. 2007 110 TDCi Station Wagon XS |
