Home > For Sale & Wanted > [For Sale] Black Sheep rear crossmember.
Bathale
United Kingdom 1998 Defender 90 300 Tdi PU Rioja Red
For sale……..
This Black Sheep crossmember was fitted to my 300Tdi 90, 18 months ago. I have now fitted a new galv chassis.
Black Sheep crossmembers are no longer available. They are made from 6mm steam plate and formed into a ‘C’ section, fully gusetted and fully welded. They are incredibly strong, easy to keep clean due to the ‘C’ section.
It has been removed with a good section of the chassis (with rear spring mounts). The inside of the chassis legs are relatively free of rust and generally in good condition. My chassis failed behind the gearbox crossmember and at the front end.
The crossmember is located in Bristol, and for collection due to size and weight.
Price, £150.
Post #908017 15th Jun 2021 8:35pm
Busarider
Anyone know if this will fit my 00 td5 90
Post #908047 15th Jun 2021 10:38pm
What do you mean by "steam plate" ?
Post #908054 15th Jun 2021 11:01pm
Co1
Possibly means “steel” plate?! Autocorrect?!
Post #908064 16th Jun 2021 6:10am
Mountain_man
Wales
It would fit but won't have the brackets for the rear mounted fuel tank (I think yours will have this set up?) . They could be cut off the old chassis and transferred over I guess. I have just fitted a TD5 rear chassis to a 300 tdi and that was the only major difference I saw.
Post #908076 16th Jun 2021 8:24am
Ah, of course! Thanks, that makes more sense.
Why didn't I think of that...
Post #908082 16th Jun 2021 8:51am
AJC
But by right a TD5 should have a hole for electric plug
Post #908103 16th Jun 2021 10:12am
Mountain_man
Wales
^^^ ah yes, you are correct. It did have the hole too. Though that is not a structural issue with fitting to a TD5 since most tow bars offer a braket for the plug too. The lack of tank brackets on the other hand, would be problematic!
Another difference should be that the tdi cross mamber has the body tabs welded on while the TD5 uses a seperate bolt up section with the tabs a part of that. Since this one doesn't have the body tabs I assume it relies on a TD5 type bolt on section too?
Post #908109 16th Jun 2021 10:49am
excossack
I ordered a Blacksheep x-member a few years ago, and didn't come with TD5 electrics hole. I think, it was boiler plate that was used...? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #908114 16th Jun 2021 11:23am
Pacha
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
Boiler plate is often referred to as steam plate - its a hot rolled special carbon steel. Rgds.
Chris
Post #908117 16th Jun 2021 11:28am
rallysteve
Same here, my Blacksheep X-member for my TD5 didnt have the hole for the towing electrics. I ordered mine with the older style body mounting tabs though. I am sure it was S355 steel he used.
Adding the electrics hole would have added a fair bit of effort/cost although I am sure Clive would have done it if asked. He fitted two exhaust cutouts in the one for my V8 90 and reinforced them with hydraulic cylinder sections (10mm wall) as he wasn't satisfied with the wall thickness of the available tube in that diameter Rolling with laughter
Post #908120 16th Jun 2021 11:45am
Bathale
This crossmember come with a galvanised TD5 style fitting bar that sits on top of the cross member, you can see the four fitting holes, hence no tabs at the rear edge. It cleans the back end up.
No electrics hole as other contributors have said.
Post #908152 16th Jun 2021 2:24pm
Indeed it is, usually a hot-rolled medium carbon steel formulated for performance at high temperatures. Apart possibly for corrosion resistance it has few properties relevant to a rear crossmember, and many properties that make it really quite unsuitable (eg prone to embrittlement, difficult to weld, and poor low temperature strength). It is also expensive, and, given that it is rare that the rear crossmember is subjected to temperatures of 650 degrees F, it would be a very odd and unsuitable choice.
Low carbon mild steel (as used throughout the construction industry for structural steelwork) has properties which make it far more suitable, such as good ductility, good strength at low temperatures, and ease of welding.
It would also be very difficult to weld a boiler plate crossmember to a mild steel chassis in a satisfactory way.
My first thought when reading the OP's "steam plate" comment was that he was saying that the cross-member was made out of one of the many standards of boiler plate, which struck me as unsuitable and surprising and is why I queried the comment. I believe however that Co1 has nailed it with his autocorrect theory. Either that or it is a misunderstanding.
For the avoidance of doubt, I am not questioning the suitability or quality of the Black Sheep crossmember, which was an outstanding product and it is a shame that it is no longer available. If I needed one, I would be snapping this up.
Post #908175 16th Jun 2021 5:05pm
Moneypit
2004 Defender 110 300 Tdi HT Fuji White
Bought one years ago just to put it to one side for the last Defender I build just before I retire,
Post #908210 16th Jun 2021 8:06pm
Oldninety
Norway 1985 Defender 90 200 Tdi HT Alpine White
Sold?
Post #1066662 30th Apr 2025 12:43am
