![]() | Home > In Car Electronics > Ex sseb 110 rear camera dead |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6216 ![]() ![]() ![]() |
Probably similar to the durite kit you can get.
CCTV is pretty simple though.... 12v to each camera and a video signal back. So get out your multimeter, check there's 12v at each camera. Meter out the returning video cable, check there's no breaks in it. If possible try hanging another CCTV camera off of it... any domestic analogue camera will do the job (as long as it's not AHD type, just basic low quality video) so you can substitute a suspect camera. For the monitor, any screen that has a composite video in (usually a yellow phono socket), or even a TV with a SCART socket you can stuff composite video straight into that to check that the cameras are still working. Or something like this: cheap as chips!! |
