![]() | Home > Maintenance & Modifications > Fuel tank replacement? |
I haven't heard of any particular problems with them so for everish is probably right, so far. Darren
All this with the tank drain of fuel
remover it check pipe work for crack replace as need clean outside of the tank remove the pump check filter screen clean if needed check inside the tank and clean good to go |
jpboost Member Since: 13 Apr 2021 Location: Gatwick Posts: 378 ![]() ![]() ![]() |
I've not got any experience of the LandRover plastic tanks, but having restored other cars with plastic ones, I'd be perfectly happy with disassembly and a good visual check. If nothing is amiss, then (as above) clean it up and reuse. I'd be replacing any hoses as a matter of course.
