Home > In Car Electronics > GPS Antenna Location
mcma1
Is there a recommended location for a GPS antenna in a defender?? On my last one it just sat in the dash and seemed ok but I just got the JLR classic head unit and would be interested to know where people are putting them?
 Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #907845 14th Jun 2021 9:37pm
boode
England 2003 Defender 90 Td5 HT Rutland Red
I have the same classic head unit and I installed the antenna under the drivers side wing top plastic vent cover
The antenna picks up a very good satellite signal and the wire threads through the rubber grommets behind the dash
I also installed the microphone for the phone connection into the A pillar
Mudstuff do an enlarged A pillar to hide wiring in- I drilled a hole into it which the Microphone pokes out of - almost level with my mouth - works very well
Post #907854 14th Jun 2021 10:30pm
MichaelE
Mine comes up through the ashtray aperture and sits between the ashtray and the windscreen. The ashtray fits back in with the cable there no problem.
Then again, I have no idea if you have an ashtray in yours same as earlier ones.
Post #907871 14th Jun 2021 11:47pm
mcma1
Post #907890 15th Jun 2021 7:00am
