Home > Maintenance & Modifications > What else should I do while the Puma dash is out? |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4003 |
You could renew the wiper wheel boxes if yours have a bit of play. Even if it’s all in good nick, you could clean the mechanism out and re grease it. 2007 110 TDCi Station Wagon XS
14th Jun 2021 6:46pm |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2900 |
Upgrade to 2 washer jets
14th Jun 2021 7:14pm |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3230 |
De rust and paint the 2 lower brackets that hold the dash. IIRC there is a ground on the driver side, next to the fuse box, so make sure you remove the paint around the hole for proper grounding.
I removed every plastic insert and sprayed ACF50 in every hole I could find behind the dash. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
14th Jun 2021 7:37pm |
