Home > Maintenance & Modifications > Injector change easy??
bear100
I popped the question on here a little while back about the white smoke and miss fire on start up only when cold. (seems to be a lot of them at the mo!)
As a result of the answers and advice i changed the easy ones - VCV, MAP, MAF and Glow plugs but yesterday i still had the misfire and smoke so am i right in saying the most likely culprit will now be a leaky injector?
If so is it a DIY job to change them? just done the done thing and googled it then watched a youtube video, it seemed pretty straight forward (they were polish so couldn't understand them).
I like to try and fix/repair everything myself to an extent not because it saves a few ££ but it gives me the knowledge on how things work in the event of a break down especially when on an overland expedition.
Thumbs Up 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #898887 18th Apr 2021 6:39pm
roel
I changed my injector seals so changing an injector is about the same. However you have to program the code in the ecu. Roel
2003 90 Td5 (2009-now)
Post #898893 18th Apr 2021 7:06pm
bear100
Hi Roel, I need to program new injectors?
If I just change the seals no programming required? 2023 Defender L663 V8
Post #898920 18th Apr 2021 10:17pm
mwestcrew
United Kingdom 2011 Defender 130 Puma 2.4 HCPU Baltic Blue
If you are just changing the seals make sure the injectors go back in the same place and no coding required.
But that won’t fix a leaking injector, it needs to be replaced. In that case the ECU needs to be told the serial numbers of the new injectors.
Once that is done you should do high pressure pump reset and a primary learn, both done using a diagnostic tool or the Forcom software or similar.
VCV generally does not cause smoke from the engine, poor performance and economy and erratic idle are the most common symptoms. 2011 130 Utility Body
2005 110 Van
Post #898925 19th Apr 2021 12:26am
Hufflepuff
Erm.... what engine are we talking about here? Injector seals have been known to leak on a Td5, but I see bear100's profile says he has a Puma. Do they leak on Puma too? 2005 Td5 90 XS
1989 V8 110 CSW
Post #899192 20th Apr 2021 5:07pm
bear100
Yep its a Puma 2.4 2023 Defender L663 V8
Post #899202 20th Apr 2021 6:25pm
mwestcrew
Yes they can leak on a Puma 2011 130 Utility Body
2005 110 Van
Post #899213 20th Apr 2021 7:03pm
TriniDaddy
2008 Defender 110 Puma 2.4 XS CSW Arles Blue
Hey guys.
I'm about to do the same thing today. Take the injectors out and change seals tomorrow. Is it necessary to disconnect the battery while I'm doing this? Or is having the key out enough?
Post #906918 8th Jun 2021 3:09pm
hank
Manual will probably say to disconnect battery but I never have. Just leave ignition off > 110 XS Double Cab
Post #906921 8th Jun 2021 3:41pm
I see no reason why you would need to disconnect the battery, but it is probably worth bearing in mind that there is a hefty permanently-live feed from the battery to the alternator not far from where you'll be working.
It is quite possible that the insulation will be chafed most of the way through, as well, so it might be wroth checking the condition of the harnesses while your head is under the bonnet. Sad
Post #906924 8th Jun 2021 4:12pm
TriniDaddy
Well. I'm almost ready to get the injectors back in. Got them cleaned, tested and serviced. Cleaned out the seats as well. Got new washers and seals.
One nozzle's a bit swollen, will have to source that some other time.
Thinking while I'm in there, might as well clean out the entire area and change the rocker cover seal as oil was coming out the back and spraying onto the firewall.
Keep you posted.
Post #907656 13th Jun 2021 4:09pm
bear100
Keep us posted and let me know how the engine is after Thumbs Up 2023 Defender L663 V8
Post #907659 13th Jun 2021 4:26pm
TriniDaddy
Ok. So!
Took the rocker cover off yesterday to check the seal to see if it needs changing and clean the face a little bit because of the oil I'm seeing that drips down every time I'm driving.
I thought it was because of the swollen nozzle or whatever caused that. But pretty sure THIS is the culprit right here!
Whatever sealing material that is, it's broken just there and the oil is spitting out I guess it's gotten worse over time and there may be other spots I'm not seeing. Either way the whole thing has to be removed and done over. Will have to get that done professionally. I don't think I should risk moving more parts on my own. Plus I don't even know what it's sealed with!
The saga continues...
Post #908018 15th Jun 2021 8:37pm
hank
Wouldn't worry too much about the excess sealant being 'broken' on the exterior... It will still be in place between the mating faces > 110 XS Double Cab
Post #908023 15th Jun 2021 9:00pm
TriniDaddy
Ok. So where you think the oil is coming from then?
I want to explore all possibilities before I put the injectors back in.
Which reminds me! Is there a company I can get replacements injectors nozzles from online? I'm in Trinidad and so far only seeing them available from Chinese and Turkish sites.
Post #908056 15th Jun 2021 11:11pm
