Home > In Car Electronics > Trailer warning light
Page 2 of 2 <12
If it’s multiple circuits, it can be a single shared ground point.
I would imagine it’s a bad earth or loose eyelet, then if that ground point is shared to then creates voltage leakage into other circuits which then causes random issues.
The key I found to tracking down the culprit on mine was the multimeter checking for ground resistance on different circuits.
The ground should be as close to zero Ohms as possible, if you find a high reading instead then you can zero in on that ground run.
I’m sure you’ll find it soon. Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #906228 2nd Jun 2021 10:29pm
barbel jim
All sorted! Another session tonight, my first mistake was that I’d been looking at the wiring diagram for a pre2002 td5 Laughing
Anyways o/side wheel off and start removing the conduit that houses all the wires. I was expecting something similar to the near side, but they did a good job , that side was a pig to get off, and wires like new, so nothing obvious. I then took the earths off the transfer box nothing noticeable but cleaned up and bolted back on more in hope..... but no change Rolling Eyes
So then I spent the best part of 2 hours with the multimeter checking the earth wires resistance...... nothing obvious and all low readings. Out of desperation I took the bulb holder off the stop tail on the offside and although not dirty cleaned it and still no change!!
So I then tried a new bulb even though the other one worked .......
Sorted Thud
All that for a 50p bulb Rolling with laughter
Thanks for peoples suggestions. Hopefully this thread will help someone else Rolling with laughter
Post #906381 3rd Jun 2021 9:17pm
90 Dreamer
At least its sussed.......
Had a similar thing years ago with a friends car that lit the headlights when the brakes were applied, took ages to sort until we realised that it had previously had a dual filament tail bub replaced with a single filament variant ans was effectively shorting across the holder......took a bit to find Cool
Post #906391 3rd Jun 2021 10:05pm
JoolsB
United Kingdom 2011 Defender 90 Puma 2.4 HT Orkney Grey
My trailer light on the dash has been on since I got my defender, I had a look at a few things then decided I could live with it!
Post #906452 4th Jun 2021 12:52pm
90 Dreamer
do you mean its on permanent or flashes when the indicators are first initiated??
if its the latter then thats normal only flashing permanently when you connect a trailer plug
Post #906466 4th Jun 2021 3:11pm
Glad you found it, it really is a headache I know I’ve been there with similar issues before.
Every new issue can be a surprise, the most odd things can crop up. Laughing
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #906485 4th Jun 2021 6:27pm
barbel jim
Yep it was a PITA ! You know it’ll either be 10 minute job or several hours, in the end it was both. Worth it though. I think I had 2 issues the frayed wires on the near side coupled with the dodgy bulb. The state of the wires on the near side convinced me it’ll be damage/ wear causing a short/earth issue. When I didn’t find any I was then sure it would be an earth fault. The bulb change was desperation Laughing
Post #906498 4th Jun 2021 8:36pm
Page 2 of 2 <12
