Home > Faults & Fixes (L663) > Interior lights continuously on |
rutiger Member Since: 30 Dec 2020 Location: wa Posts: 32 |
you're adjusting the light level with the knob yes? #8 here https://www.ownerinfo.landrover.com/docume...c/G2401208
3rd Jun 2021 1:27am |
Tom_T Member Since: 08 Nov 2020 Location: Essex Posts: 87 |
Yep I can manually dim them down using the switch below the steering wheel. I just thought that the lights in the boot would switch off whilst driving and all the others would automatically dim?
3rd Jun 2021 5:09am |
Simon Audi Member Since: 19 Nov 2020 Location: Newport Posts: 544 |
They should turn off after a time yes
3rd Jun 2021 5:14am |
Okay. Looks like I’ll have to take it in then as they don’t turn off. Even when I get the message “interior lights off” they are still on. Hopefully it’s just user error and I’m being a dullard.
3rd Jun 2021 6:47pm |
Popped in to see the service manager this morning and show him what was happening with the lights. He agreed that something was definitely not right so it’s booked to go in on the 16th for some investigation. Annoyingly they aren’t issuing any courtesy cars due to COVID so hopefully it’s just in for the day as any longer will be a real problem for me.
Will post an update once the car has been in. |
4th Jun 2021 12:39pm |
Let your battery go flat - call our LR assist and you should get a courtesy car
4th Jun 2021 12:55pm |
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3250 |
No loan cars because of covid, rubbish!
If they can’t give you loan car because of covid then I assume if one were to ask for a test drive that would also be off limits? 24MY 90 D250 HSE, Tasman Blue |
4th Jun 2021 5:16pm |
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3751 |
The interior lights up by the mirror may have been touched accidentally when adjusting the RVM - they have proximity sensitive coatings so just put your finger or hand near them when you have closed the door and they will go out. Touching the light fitting smoked surface will set them to stay on automatically, there is one tiny tiny down lighter that in previous modern Land Rovers and RR’s is called waterfall lighting, that one stays on when the engine is running but as you hardly see it even on the darkest night you cannot switch that one off.
The variable adjuster down by the parking brake doesn’t seem to do much on my car Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come 2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
4th Jun 2021 6:16pm |
It is a load of rubbish but I think they are just avoiding giving out cars for a day. I have a feeling that if there was a major problem and they needed the car across a number of days then they would loan me a vehicle. For one day I can live with dropping it off. Let’s see how things go. |
4th Jun 2021 8:54pm |
It seems to be something to do with the programming. It’s tricky to explain but when the main dipped beam lights are off I can touch the dome light and it will come on, and then turn off again when I touch it. When the main dipped beams are on, the dome light (and all other interior lights) stay on permanently and it makes no difference if you tap the light they just do not turn off. Simon from powerful uk posted a video a while back showcasing the interior lights and you can see from his video that his main dipped beams are on, yet he is able to toggle the interior lights on and off by tapping the central dome light. So I know that there is a fault with mine as mine don’t function in the same way. The waterfall light is also always on but like you say this is supposed to stay on. My old Range Rover had this as well. |
