![]() | Home > Puma (Tdci) > What size are these TX Flywheel bolts on my 2015 2.2 Puma? |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18044
If a TX55 is loose but won't spin, it is pretty certain to be TX60, since a TX55 will as I recall spin in a TX70 socket. If it is any help, a TX55 is 11.35mm across lobes, a TX60 is 13.45mm, and a TX70 is 15.70mm, so the three are distinctively different.
I'm not sure quite what you mean with your "final torque" question since you quote the spec, first stage 25NM, second stage 45NM, then a further 45 degrees. You'll need a torque wrench and an angular torque gauge. |
| Gleo Member Since: 01 Mar 2016 Location: Mayo Posts: 43
Super thanks Blackwolf for the feedback. I don't have an angular Torgque guage hence was just wondering what the final torque figure should be if using a standard torque wrench if one doesn't have an angular TG.
| Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3650
360 degrees is a full revolution.
45 degrees is 1/8th of a revolution. 45 degrees is half of 90 degrees. 90 degrees is a right angle (the angle between 12 o'clock and 3 o'clock), so just calculate half of that on your wrench to get 45 degrees. Make a cardboard template to help you get the angle more precise. I am sure it is still ok if you miss it by a few degrees. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
You can't do it just with a torque wrench, I'm afraid.
Something similar to this tube: but of course 45deg not 60.
But do not know how critical the flywheel bolts are. Safer to have an angular gauge, and then you are sure that you torque correctly. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Thanks guys got a TX60 earlier, and it was indeed the correct size.
Got the spigot bearing done this evening, some fun getting out Thanks for all the feedback above guys. |
| All times are GMT |
