Home > Puma (Tdci) > Can anyone recommend a retrofit AC kit?
Co1
As per the title. Also, are there any I should avoid as well?
Col
Post #905758 30th May 2021 5:56pm
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
Cool air Logan in Lincoln do various options 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #905760 30th May 2021 6:07pm
trailbear
Company called audiofile incar in Bishop Stortford, I have used them several times.
They have extensive experience in all things Landrover. Long drive for me but worth it in my opinion.
Give them a call and they can run through it with you. There is a fair wait time but as I said worth it.
Post #905774 30th May 2021 10:26pm
ozzie1989
Wales 2010 Defender 110 Puma 2.4 USW Bonatti Grey
I bought a kit from Bearmach (on offer) that turned out to be a Cool Air Logan kit.
Very hard to tell apart from the genuine setup (apart from grille of course) and uses genuine AC hoses and compressor, coupled to their super thin radiator.
Took me 2 days to fit on my drive, first day doing the inside, second day in the engine bay.
I then used ATS Euromaster to fill it up, before it gets filled the machine conducts a pressure test on the system for leaks etc. and it was spot on with no loss of pressure. It's worked flawlessly ever since, probably about 4-5 years since fitted. Now: 2010 2.4 TDCi 110 Utility Wagon
Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition)
Post #905779 30th May 2021 11:08pm
