Home > Puma (Tdci) > Limp mode when driving in traffic
Howard
We have a problem with our 2.4 (2010) Puma. When driving slowly in traffic the truck will go into limp mode. No engine warning light. Sometimes it clears quickly, other times it can take a few minutes to clear before she runs ok again.
Would a dirty ERG through up this fault ?
I would be grateful for others thoughts on the cause of the problem.
Post #873750 19th Dec 2020 2:34pm
NL_Defender_90
Netherlands 2011 Defender 90 Puma 2.4 X-Tech LE Nara Bronze
Mine had the following issue:
When driving into traffic after a long run, so warm engine, it would sometimes become unresponsive on the gas pedal. Car keeps running, but no power or revs (above idle). Quick fix was turn car off, and start again and wait until it happens again.
According the dealer they solved the issue (under 3 months warranty) by replacing the switches for the brake lights in the pedal area.
Edit: also no warning lights or error codes.
Post #873753 19th Dec 2020 3:49pm
Howard
Thank you for your response, all good for a couple of months, but the same problem is back again.
Post #905177 26th May 2021 7:32pm
Kevlar
Czech Republic 2010 Defender 90 Puma 2.4 SW Santorini Black
Try to accurately measure the engine coolant temp when this happens. Mine was doing this but it was related to over heating. At about 112 deg c it would go into limp mode, then when it cooled it would go back to normal.
Kev
Post #905366 27th May 2021 8:02pm
That would be my thought, too. It's a self-preservation measure in the event of overheating. It could be something like a faulty viscous fan, which would lead to overheating in the circumstances that you describe, or even a faulty cylinder head temperature sensor making it think that it's over heating. Darren
Post #905416 28th May 2021 6:21am
