![]() | Home > Maintenance & Modifications > Dot5 fluid in a Defender |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3646 ![]() ![]() ![]() |
Yes, I read that dot5 and ABS do not go well together because dot5 can can aerate when the anti-lock brake system is activated. That can give you the spongy pedal feel. Not good.
But my old 90 has no ABS, so that would not be an issue. There are also claims that dot5 is more compressible. I was always taught that all liquids are incompressible.... but even if it really was, perhaps it can be compensated for with braided brake lines! Most of the reading I have done is on mountain bikes, where some users have switched from dot5.1 to dot5 without issues. Perhaps there are a lot of myths out there, and of course car manufactures who tested their vehicles on dot3 will not tell you that dot5 will work as good. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2416 ![]() ![]() ![]() |
Doesn't DOT5 rot rubber seals ?
Apparently rubber seals can swell a little, which can be a positive thing as the seals will seal better.
Seems that need to keep away from silicone seals with Dot5. Silicone seals with silicone fluid is not ok. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2308 ![]() ![]() ![]() |
Its more compressible because it does not absorb moisture and hence when the temps rise the water turns to gas and suddenly no brakes.......... Its not in common use for a very simple reason, it has BIG issues day to day |
I get exactly what you mean 90 Dreamer. I should measure caliper temperature for my use. I do not want to do anything stupid that would regret later. I will find some day and push the Puma a bit hard, and measure that, although unsure if that is representative as there are quite some differences in the braking system, vented, larger pistons but more mass to stop. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Did a few runs in my 90, ambient temperature 20dC. Front brake calipers just slightly warm to the touch. Rear calipers cold.
Perhaps did not push the brakes hard, but I checked on a trip when I was mostly going downhill. So I guess dot5 is perfectly fine for my use. So I ordered 1 liter of dot5. Was not easy to find locally, some so called agents do not even know what dot 5 is. Always got offered 5.1. Perhaps 0.1 is insignificant, right? ![]() It is bloody expensive liquid. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Dot5.1 is NOT any relation to dot5
It shares its background wth dot 3 & dot4 which will all mix and was originally developed specifically for certain ABS applications - it would have been a far better option IMO |
Yes, I am sure the other brake fluids are better performance wise. Just do not want to cry over spilt brake fluid (or leaky cylinders). Too many hours spent cleaning and painting. With dot3 or 4 I used to get a bit of white paste, better known as aluminium oxide on the cylinders from lack of use. Hence want to try dot5. Will be the first time for me.
![]() Click image to enlarge ![]() Click image to enlarge 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
