![]() | Home > Maintenance & Modifications > Dot5 fluid in a Defender |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3615 ![]() ![]() ![]() |
Gents, for my 90 restoration I have been pondering if I should use Dot5 for the brake and clutch hydraulic fluid. The only reason is because Dot5 does not eat paint.
There is a very good explanation by Oilman here: https://www.defender2.net/forum/topic4739.html?highlight=dot5 The main downsides are water that can pool and cause localized corrosion (can steam up as well) and lower lubrication. Has anyone used Dot5 in his Defender, Series or any other classic car? If yes, were the above downsides serious that warrant not to use Dot5. Once my restoration is completed, it will live in a warm garage, will avoid wet weather, will not go wading, and will not see high speeds. So the water/steam issue might not be that big for me. Thoughts? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4332 ![]() ![]() ![]() |
My Dad has used it in his gently driven MG for years with no apparent issues. I don’t actually know why he uses it, but he seems happy with it. 2007 110 TDCi Station Wagon XS
A bit off topic, but given brakes are hydraulic system, why don’t they use hydraulic oil? I guess it’s to do with viscosity through the tiny pipes, but not sure. 2007 110 TDCi Station Wagon XS
I read online that performance wise it is the lesser than the other dots. But how much less performance. 1%, 10% 50%? And when talking about performance is it braking power, or brake fade at high temperature? My experience with LandRover hydraulic systems is not if it leaks but just when it will leak. I am not a heavy brake user, I use a lot of engine braking. IIRC, the brake pads on the 90 lasted around 80kmiles. So probably temperature is not an issue for my use. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Yes, probably gentle is the key word here. It will have a 19J, so gentle will be. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2542 ![]() ![]() ![]() |
Yes viscosity due to small bore pipes and orifices is one reason. Another is that hydraulic oil absorbs oxygen bubbles and therefore is undesirable in a braking system the same as air in a braking system. Also hydraulic oil is flammable and therefore any fluid leak onto a hot brake disc could cause a fire. Defender 90XS SW
Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 781 ![]() ![]() ![]() |
Flammable, much lower temperature operating range. Rgds. Chris |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2288 ![]() ![]() ![]() |
can confirm that Brake Fluid is also very flammable as are most fluids on a vehicle............ATF is another
RFT Member Since: 13 Nov 2010 Location: Yorkshire Dales Posts: 694 ![]() ![]() ![]() |
Brake fluid is a type of hydraulic fluid, Hydraulic fluid is any fluid that transmits force by means of hydraulic pressure, water is a hydraulic fluid. 130 Puma HCPU with an Artica 240LR Demountable Camper |
There are many industrial Hydraulic oils with much higher operating temperature ranges as used in steel making, glass furnaces, cement plants. Many of these oils have very low flammability, it takes an atomised spray from a very high pressure system to hit a hot surface or open flames for them to ignite, in my 5 years as a Steel Works Engineer I saw very few hydraulic leaks ignite fortunately but those i did see I'll never forget, the radiant heat given off by the flames is unbelievably hot. 130 Puma HCPU with an Artica 240LR Demountable Camper |
Forgot all about it, but many moons ago I used to have a Citroen BX. That the one with hydraulic suspension. The braking and suspension system used the same LHM fluid. Cannot recall if it was corrosive and paint damaging though. Quick google search seems to be a mineral oil. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
I think Rolls Royce used the same fluid as Citroen’s too, as they used a licensed version of the Citroen brake/suspension system 2007 110 TDCi Station Wagon XS
I agree - whilst it might not be great for paintwork, why would this be a massive concern? I cannot recall anytime in the last 40 years that I spilt brake fluid on the bodywork of any vehicle. Rgds. Chris |
^^^ True, brake pipes are very reliable. But I am more concerned about bulkhead/footwells. If the clutch master cylinder starts leaking, all the oil will go in the footwell. If not noticed early enough, due to carpets etc, that area would soon end up with soggy paintwork. The brake master cylinder is further out of the bulkhead and will only damage the paint on the servo.
Perhaps Dot5 for clutch (less critical component) and Dot4 for brakes! I read online that military vehicle use Dot5, but the reason being that these vehicles are idle for very long periods, and they need to go in action without prior notice. So perhaps there is also other benefits for vehicles that are not used on a regular basis. Less chance that the brakes seize up?? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
