Home > Maintenance & Modifications > Dual battery size/fitting advice
j17
Hi guys,
I'm after some advice in fitting second leisure battery in a puma.
In this thread
https://www.defender2.net/forum/topic61567.html
Cupboard says you can fit 2x 019 batteries in and I'm sure I read somewhere you need to rotate them or something? (however I can't find that thread any more)
I bought a second battery, a bosch leisure battery. The garage I took it to, said it wouldn't fit in a puma seat box due to the angled/sloped section.
Is the only way to fit them to remove existing tray and make a new one?
Any help and pics/links appreciated
Cheers,
Jit Jit
Instagram @magars_on_tour
Post #904134 20th May 2021 7:55pm
Bluest
I have 2 batteries, the standard starter battery, plus an AGM leisure battery the same size. They fit side by side in the normal orientation, but the starter battery needs to be moved a bit further forwards and most importantly moved towards the door side (left), such that it slides under the lip of the seat box opening. I had to make a battery tray to hold it all in place, but it was pretty simple snd used the original mounting holes.
I’m sure I posted a thread on here about it, but it would have been 3 years ago or so. 2007 110 TDCi Station Wagon XS
Post #904135 20th May 2021 8:02pm
j17
Post #904149 20th May 2021 8:52pm
