Home > Puma (Tdci) > Wind-up backlash???
ZeDefender
Wind-up backlash???
Please can someone explain (in idiot-speak) what "backlash" and "wind-up" are. I've seen the terms used many times in forums but never simply explained. How are they affected by how you change gear?
Many thanks, as ever,
Matt
Post #90388 21st Sep 2011 3:33pm
Happyoldgit
Not affected by gear change but rather the different rates of rotation of the wheels. Steve.
http://forums.lr4x4.com
Post #90398 21st Sep 2011 3:58pm
BigMike
look on wikipedia for backlash, its a big subject but quite simple.
wind up - on defenders, you engage the CDL and drive with it in. you come to disengage and it wont. torque has built up due to the differences in the rotational speeds of the wheels. on gravel its not really an issue, though can be if the surfaces change to harder ones and CDL is left engaged. its the reason why you should never use the CDL on tarmac. And many people use the CDL too much, leaving it in for long periods when really it should be used for short periods and small distances. if you continue to drive on tarmac with it engaged, you will damage the transmission. way to "unwind" it is to either put the wheels of one side of the vehicle on hard ground like tarmac and the other side on gravel or grass. drive back and forth a few times and it should come out. if it doesnt. on lose ground go lock to lock whilst slowly reversing, that never fails (in my experience)
ETA - it can actually be affected by how you change gear (though more how you drive really)eg youre going up a wet rock slope, you engag CDL, drop a gear and gun the engine hard. if all the wheels grip and you're on an angle it can lead to wind up. The harsher you are on the gas the more chance of wind up, but drive normally and it should be fine.
Post #90401 21st Sep 2011 4:03pm
Grockle
no Mike,'wind up' is when some one is having you on
Back lash is when you get the last round in, simples Wink 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #90406 21st Sep 2011 4:18pm
BigMike
no grock, backlash is what YOU get when YOU dont get the last round in Laughing
Post #90416 21st Sep 2011 4:33pm
Grockle
Laughing Thumbs Up 2.4 90 XS
Post #90425 21st Sep 2011 4:46pm
ZeDefender
So for my Landy, backlash is the (not too serious) jolting feeling from the T-Box/props etc. as it takes up drive?
Post #90440 21st Sep 2011 5:41pm
Happyoldgit
No, backlash is what happens if you are not careful when you have to let the rounds out Laughing Steve.
Post #90452 21st Sep 2011 6:55pm
jst
yes Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #90459 21st Sep 2011 7:36pm
jst
not meaning to pick, more so to expand on the reply
in my experience people dont use the CDL enough, most seem to consider it as a get out of goal card and wait until its too late before they use it. it is a preventative system, not a reactive system like TC.
as for using it for short periods i would say that is a very general term. you use it for as long as you need to, that could mean its in for days but the distance travelled is short or long or in and back out for 10s over a 50m section
if there is a risk of loosing traction then engage it prior to loosing traction and leave it in until that risk has passed. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #90463 21st Sep 2011 7:41pm
Shax
England 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
I thought that was follow through? Very Happy ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
^^_-^-_^-^_^^^^^--^^^^
PAUL
G7ALW 14.200 USB
26FB458 / 27.275 SSB
Post #90522 21st Sep 2011 11:59pm
