Home > Off Topic > Car garage fined £80,000 over horrific oil drum explosion
Might be a timely reminder to a few on here given the circumstances.
"An MOT centre has been fined £80,000 for supplying an oil drum that exploded and killed an agricultural engineer.
Six had been provided, and an investigation by the Health and Safety Executive (HSE) found that the empty drums, which had been labelled as having contained motor oil, had also previously held highly flammable gasoline.
However, they hadn’t been labelled correctly by Stonehill MOT Centre, of Stockley Meadows, Huntingdon, when it provided them for a pheasant shoot.
Luton magistrates were told that experienced agricultural engineer Christopher Chatfield had been making metal pheasant feeders for the shoot near his home in Warboys, said the HSE.
It involved converting empty 200-litre oil containers by cutting open the lids with a plasma torch.
An inquest was earlier told by shoot gamekeeper David Clifford that more feeders had been needed so he got half a dozen oil drums from Stonehill MOT Centre where brother-in-law Dean Hurrell worked, a BBC report said.
CCTV footage showed a flash of flame when Chatfield, 58, used the cutter on the first of the drums.
He examined his face and completed work on the first and second drums.
But while he cut open the third drum, it exploded and killed him with a ‘massive penetrating head injury that would have been instantly fatal’.
The inquest was told, however, that although one of the remaining drums smelled of fuel or petrol and two drums that were scientifically examined had petrol or gasoline, the damage to the oil drum that killed Chatfield had made it impossible to tell what had been in it.
The tragedy happened on April 21, 2017 and in January 2019 an inquest jury in Huntingdon returned a narrative verdict that his death was an accident.
The case finally came to Luton Magistrates’ Court last month (April), where the HSE said there had been a failure to supply labelling to show that the empty motor oil drums had been repurposed to store gasoline, which had created a fire and explosion risk.
Stonehill MOT Centre admitted breaching the Health and Safety at Work Act and was also ordered to pay £8,167 costs.
After the hearing, HSE inspector Parmjit Gahir said: ‘Those who are involved in the sale or supply of an article or substance, in this case used oil drums, have a responsibility to ensure that adequate information is provided so that the person buying the article can ensure that it can be safely used, cleaned and maintained.
‘Failure to provide any labelling information on the used drums, to show that they had also contained gasoline, did not allow for the necessary precautions to be considered and adopted when cutting the drums open.
‘If appropriate labelling had been in place this incident could have been avoided.’"
https://cardealermagazine.co.uk/publish/ca...eer/223421
Post #903530 17th May 2021 1:03pm
I'm not trying to excuse the place that supplied the drums, but I do have to wonder slightly about the common sense of the victim.
The drums had been used for petrol, it is likely that the odour was distinctive (admittedly he may have had an olfactory problem and not been able to detect this). There was a vapour deflagration when he cut the first drum sufficient to make him inspect his eyebrows, yet he carried on cutting seemingly without concern. Hmm.
That being said, I do know someone who blew up the fuel tank of a Daimler SP250 not once but twice whilst trying to repair it, and they had previously struck me as of fairly normal intelligence, an opinion I revised after this incident. Apparently their reasoning was that there would be no fumes left in the tank after the initial deflagration, reasoning that they immediately proceeded to prove defective by causing a second deflagration and destroying the tank.
Moral of both stories: if it smells of petrol or anything that might be or have been petrol, steam clean it for several hours before going anywhere near it with a naked flame or anything that creates sparks.
Post #903578 17th May 2021 4:42pm
miker
A tragic accident for sure, but I've always been told that any drum or tank that might have contained fuel or oil (or other flammable substance) should be washed out and flushed with air for several hours to get any residual vapour out.
Post #903703 18th May 2021 11:51am
jim4244
England 2013 Defender 90 Puma 2.2 CSW Fuji White
So he started cutting one which resulted in a minor explosion and then just carried on cutting the others? Or did I read that wrong?
Jim
Post #903705 18th May 2021 12:01pm
No, I think you read it right. He singed his eyebrows on the first one, and then killed himself with the next one.
One has to wonder......
Post #903715 18th May 2021 12:54pm
SJM2018
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Aintree Green
There was a recent phase (maybe a couple of years ago), where people were converting propane cylinders into woodstoves / light fittings.
The individuals would 'empty' the cylinder (i.e. get a nice mix of residual propane and air) and then cut them open with angle grinders.
It's a wonder no one was killed; presumably they're designed to explode 'safely'.
In fact, I think it was shown on a BBC programme.
edit: There was a bbc programme - https://www.dailymail.co.uk/news/article-2...tting.html 2011 CSW XS 90
Post #903719 18th May 2021 1:04pm
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
Darwin Award
Post #903905 19th May 2021 1:44pm
boxoftricks
United Kingdom 2011 Defender 110 Puma 2.4 USW Zermatt Silver
Got to agree, the poor victim is in part responsible. Who the hell hot cuts a drum that contained oil/petrol without filling with water to remove fumes and then flushing out.....especially after one previously went pop!
Post #903911 19th May 2021 2:20pm
Filling with water and flushing isn't adequate, if it has held fuel you need to steam it. My acquaintance, who as mentioned above blew up a petrol tank, had flushed it several times before the first deflagration.
Post #903923 19th May 2021 4:22pm
Leamreject
Italy 2011 Defender 90 Puma 2.4 HT Fuji White
A chain of events here that should have been avoided, leading to a sad and very unnecessary outcome. Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do…
2011 2.4 Puma 90 HT
Post #903924 19th May 2021 4:27pm
Defender SVX
United Kingdom 2008 Defender 90 Puma 2.4 SVX Soft Top Santorini Black
Totally agree Thumbs Up
I in the past have removed the valve from a 47kg propane bottle and filled with water and left all week, emptied then on a refill of water sparked a lighter on the release gasses and been shocked to see a small flame/pop Embarassed still made an brilliant Durham Ox (home made OZ Pig)
Common sense from the so called engineer should have prevailed on this occasion especially after the first event, very sad for the family of the deceased but I can’t help feeling sorry for the garage that thought they were helping by giving/selling their old drums for a good use. Would a simple label have probably prevented this catastrophe? Formerly mao99999
16 Focus RS Nitrous Blue.
11 FFRR TDV8 Vouge SE Black Black.
08 DEFENDER SVX SOFT TOP (SUPERB)
08 DEFENDER 110 DCPU Stornoway grey (Overland Exploration Unit)
05 Fiesta ST 150 Van
04 Jaguar XKR 4.2 Supercharged V8
02 DEFENDER 90 TD5 (next years soft top project)
95 DEFENDER 110 CSW 300 TDi Phoenix black
95 DEFENDER 90 HT Monti Carlo blue COUNTY 300 TDi
67 109" SERIES 2a TUNED 200 TDI
64 DAVID BROWN 990 rat look
55 86" SERIES 1
Post #903933 19th May 2021 5:06pm
Bluest
It’s likely the garage came cropper because they effectively sold the chap a barrel containing a hazardous substance in a container that was labelled as containing something else. That brings with it a whole raft rules and regs which probably weren’t followed. Imagine the paperwork required to handle and sell someone a drum of fuel vapour. 2007 110 TDCi Station Wagon XS
Post #903942 19th May 2021 5:55pm
Defender SVX
A flammable liquid “nominally empty” vessel is considered more hazardous under ADR regulations ie a empty petrol tanker is more volatile so still in scope for road transport until purged and cleaned with a recognised EFTCO certification.
A standard 205 litre “lubrication oil” drum isn’t considered hazardous for transport either full or nominally empty (a petroleum would) but may be considered so as part of COSHH.
Obviously what has happened is the garage has utilised the old lube oil drums for probably storing some misfueling residue thus not labelled correctly.
As I rarely handle packaged hazardous goods anymore I probably should look up/know Embarassed the rules of nominally empty drums and IBCs but I’m fairly sure they come under both COSHH and ADR that require correct labelling and correct UN rated packaging.
The garage were probably found liable for the breach of the above that became a fatal incident hence the severity of the fine. Formerly mao99999
55 86" SERIES 1
Post #903956 19th May 2021 7:16pm
