Home > My Defender > 1989 Eastnor Green 90
Page 3 of 3 <123
Dinnu
It is also missing the bracket for the clutch flexible hose Whistle 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #903666 18th May 2021 6:03am
Woody3
United Kingdom 1989 Defender 90 200 Tdi HT Bronze Green
You saved me there! Luckily, I had one that I could whip off another bulkhead.
Anyway, bulkhead has been dropped off at the galvanisers now, along with an assortment of brackets!
I also picked my paint up yesterday!
Wasn't expecting this many tins. Just hope I use them in the correct order Laughing
Post #903882 19th May 2021 11:33am
jim4244
England 2013 Defender 90 Puma 2.2 CSW Fuji White
What a great project. I can’t wait for the next instalment!
Jim
Post #903884 19th May 2021 11:42am
mrfirepro
United Kingdom 1996 Defender 90 300 Tdi HT Bonatti Grey
Don't forget T wash and degreaser for the newly galved bulkhead
Post #903892 19th May 2021 12:32pm
Dinnu
Did the paint man give you the banana as well? Rolling with laughter
Looking forward to this thread. Doing a restoration myself.. so trying to pick up tips from others as I go along. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #903931 19th May 2021 5:00pm
Woody3
Haha - I'd have liked a crate of bananas for how much it cost! Laughing
Another update.
Bulkhead and assortment of brackets are back from the galvanisers! And it's come out pretty good!
The photos don't do it justice. Got a bit of tidying up to do around the welds and retap the threads before I t wash it and get it ready for seam sealing and painting!
For anyone thinking of doing the same, just ensure you get it acid dipped as opposed to shot blasted. I didn't brace it as I was concerned about the galv not covering areas where the fixings would have been - whether it's warped or not is yet to be seen, but I don't think it has!
I used Worksop Galvanising ... It was a week turn around and didn't cost as much as I expected! Wouldn't hesitate to use them again!
Post #905316 27th May 2021 2:50pm
Retroanaconda
Why not shot blast?
The acid dip is part of the galv process anyway is it not?
Post #905322 27th May 2021 3:21pm
Woody3
Hmmm I wasn't aware of them offering an acid dip process prior to it being galvanised - I used two separate companies...
Apparently you can't get into all the cavities with the shot blasting media, so when it gets dipped, the zinc won't adhere properly in these areas (where the door pillars have previously been filled with wax for example). Acid dipping strips everything inside the cavities, allowing the zinc to adhere properly.
The galvanisers said they had stopped doing chassis's as people were bringing them in shot blasted, but the cavities still had remnants of waxoil in them, causing mini explosions, consequently damaging them! Confused
Post #905328 27th May 2021 4:20pm
Dinnu
Nice results there. Makes me wonder if I made the right choice not to galvanize mine. But as you say, the bulkhead needs to be stripped of old waxes and paint. Acid dip does not do that. It needs to be alkali (paint strip). The galvanizers do acid dip to clean off any rust, and prepare the steel. Acid will not remove the paint. My problem was that I do not know of any local company that does the paint strip (full dip). Hence my decision not to galvanize mine Big Cry
PS.. when I eyeballed my bulkhead from one door pillar to the other, they are not perfectly parallel. And I did not do any welding or other heat treatment to it!!! the doors were perfectly aligned before I dismantled it!! 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #905388 27th May 2021 9:50pm
Woody3
Ah, I may be using the incorrect terminology then! Embarassed I used a company called Prostrip, who literally stripped everything from the bulkhead, paint, wax, oil and rust without shotblasting.
Just found the stripping process on their site www.prostrip.co.uk/stripping :
Stage 1 - Decontamination of all organic materials including paint & underseal
Body shell loaded and secured on a protective frame for treatment. This process is automated and cycle time is determined by the amount of contaminants removed. Average process time 8-14 hours.
Stage 2 - Blow off high pressure air jetting to remove residues
Stage 3 - Phos-Strip™ (Full immersion)
- A chemical tanks containing the Phos-Strip™ solution. Its this part of the process that kills corrosion. Here any rust is dissolved.
Stage 4 - Passivation
The body shell is rinsed with a mixture of corrosion inhibitors to neutralise the chemicals.
Stage 5 - Welding/Repairs
At this stage the metal is now clean and free of rust and paint. Any necessary repairs can now be carried out before zinc coating
Hope that clarifies my earlier posts Embarassed
Post #905402 27th May 2021 11:43pm
Woody3
I really need to update this thread more often!
What's been done:
    - The whole chassis, including axles are now protected with Corroless paint.
    - Genuine LR dampers installed all round (Thank you 90 Dreamer!). Looking for a set of of genuine springs from a 90 CSW, if anyone has a set gathering dust?
    - Rear tub and Bulkhead installed together with ancillaries and wiring loom(s)
- Front wings are in the process of being installed
- All of my panels, apart from the roof, wheels and the bonnet (still looking for a straight one!) are now painted too!
Still quite a bit left to do, but I think it's finally taking shape...
Post #933719 15th Dec 2021 7:59pm
Dinnu
That is very good progress. And is looking good Thumbs Up 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #933788 16th Dec 2021 7:41am
Woody3
Thank you Dinnu Smile
Post #934182 19th Dec 2021 3:04am
Page 3 of 3 <123
