![]() | Home > Maintenance & Modifications > ARB compressor where to mount |
Lightwater Member Since: 28 Jun 2020 Location: Sydney NB Posts: 75 ![]() ![]() |
Did you stick a tank in?
If not, it is really worthwhile. You fire up the compressor/s so it's ready with its full tank. Also when you are between tyres you are building up the reserve again. It's not a lot but it is worthwhile. Also the compressor will not be turning on & off as frequently. I removed the ARB fittings on the tank & replaced with my own, they seem to be bonded in, but I did crack the joint hitting the end of a spanner while kneeling on the tank. Eventually getting the fittings off. I actually have a second tank which I was hoping to fit in the car. But I would need to move the boot compressor somewhere else. So still thinking about this mini project! The ARB tank is not 4L as I filled it with water & measured it. It's about 3.7L so 1 gallon! Visitor - Freelander owner |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2413 ![]() ![]() ![]() |
I like that Michael, nicely done. Where's the window box from ? Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
The air line coming out of the compressor gets seriously hot. If it is not cooled at the connection well enough you really should use a metal braided hose for the first half metre or so. Then a rubber hose, not a plastic hose as supplied, for at least a few metres. If you have an air tank it will dissipate enough heat inflating 4 tyres. Ideally the air should be at ambient temperature when it reaches the tyres or filter if you have one. Visitor - Freelander owner
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3358 ![]() ![]() ![]() |
[quote="Mo Murphy"]
Rough Parts WARNING. This post may contain sarcasm. |
Three ARB compressors inflating while engine is running 255/60R18, about 60 litres volume. 20 - 35psi 27 seconds or 15 - 40psi 47 seconds. The pressure sits around 112psi according to the pressure regulator.
So if I wants to speed this up I will need to add a fourth compressor. If this gets close to the my current cut off if 135psi then a 150psi switch will be required. ![]() Click image to enlarge Visitor - Freelander owner |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 2027 ![]() ![]() ![]() |
Mo that is really neat!
![]() 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
It's not me bear, its Michaelkan ! But you're right it's very good.
