Home > Td5 > Red light in speedo
Paulo RB
United Kingdom 2000 Defender 110 Td5 Heritage LE Bronze Green
Red light in speedo
Hi, recently joined and been watching / searching for help, any pointers appreciated.
110 Td5 Heritage, year 2000, owned for 2 months now. sometimes the red light in speedo flickers on, sometimes off, sometimes on constant _ is this connected to factory alarm / immobiliser please?
The key fob seems to work intermittently also, could it be a flat battery in fob. ( both fobs do the same. And horn alarm drives me mad)
Thanks in advance, Paulo Paul RB
Post #902230 9th May 2021 7:25pm
dorsetsmith
fob battery's CR2032 3V
https://www.defender2.net/forum/topic76517.html?highlight=alarm
DO you have volumetric sensor. fitted in side Question
also door pile switches can cores problems
Post #902236 9th May 2021 7:59pm
Paulo RB
Cheers for that Paul RB
Post #902238 9th May 2021 8:07pm
Ianh
Just remember to follow the procedure in your handbook when fob battery changing. Then once battery changed go outside the vehicle with doors closed click the lock button on the fob four times and it will re sync. Then unlock with fob and make sure it is on the same key ring as the ignition key when starting .
Here is the process for fob battery change https://www.defender2.net/forum/post832168.html#832165
Post #902243 9th May 2021 8:21pm
Paulo RB
Very Happy Cheers Paul RB
Post #902244 9th May 2021 8:26pm
Beero
Just had a look at my handbook. When the key fob battery needs replacing the fob will only work every other time when disarming, also the hazards will not flash when disarming
Post #902270 9th May 2021 10:35pm
Paulo RB
Thanks all for comments, battery changed in remote no drama, all good again, tks. Paul RB
Post #903339 16th May 2021 8:39am
