![]() | Home > Technical > Amber engine warning light! |
| spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4813
Could be something as small as a monitoring sensor but there is noway of knowing until you get it plugged in. 1982 88" 2.25 diesel
| BigMike Member Since: 13 Jul 2010 Location: Lancashire Posts: 2253
well you need to know what the fault is. no one can answer your question without knowing the fault code, so if you dont have a diagnostic yourself, you need to go to a dealer.
if you have an android phone you can download an app called "torque" and also you need a bluetooth key for the diagnostic port. total cost about 120 sterling. |
| markieboy Member Since: 22 Jun 2011 Location: Poland Posts: 21
Off to the dealer I go then! Thanks for your quick replys boys!
| Gil9713 Member Since: 11 Sep 2011 Location: Colchester Posts: 94
Markie,
Be interested to hear whether when they plug in to see if it is showing P1169 Fuel issue. Just had mine replaced yesterday, when all were saying it was the EGR valve and something else. Clearly as stated by previous person when they plug in it should tell them straight away hopefully mate, hope you are still under warranty or extended it. |
| Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
All As long as the defender didn't enter limp mode I wouldn't get in a panic over the MIL being illuminated. Chances are that after three driving cycles the lamp will go out unless the tested DTC keeps failing the tests. Chances are though it will be a sensor issue, (most likely MAF as your defender is 4 years old. I'm guessing this as there is no dtc code available). The only way to know for sure is to plug in a diagnostic tool and see what dtc is logged. You should also consider getting some kind of faultcode reader as the dealers usually charge one hours labour to connect it up and read the codes which is a 5 minute job. There are numerous basic readers like BigMike suggested, others to consider are Scangauge 2, Nanocom evolution, Bearmach Hawkeye etc. HTH Brian. |
Bri is definitely your man for fault codes and the like
| Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897
Does it reappear when you turn the engine off and restart it?
My TD5 does it often but resets next start. Fault code reading always says crankshaft sensor. Have replaced it twice with no improvement. |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
If it something like a MAF Sensor related code (P1103) it could well be gone by the time you get to your dealer. Three driving cycles and they reset automatically as mentioned!
Doh!!!! Just re-read the thread and Lorryman had beaten me to it! I know....If you snooze you lose! it is getting late... Treat every day as if it is your last....one day you will be right!! |
Thanks for all your help. Going to invest in fault reader like you all suggested! I'll let you know what outcome of the engine light was! Thanks to all!
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21022
Had exactly the same recently. so had AA out to look ( I was unwell at the time) EGR valve fault nothing to worry about cleared code and all sorted!
| bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189
Hi, please could advise a bit more detail re the blootooth key. Thanks BM52 |
found the android app: https://market.android.com/details?id=org.prowl.torque&hl=en
found what I think is the cable but it is $ at a scary price....! need to get up off the floor and have another look around the web. Question - do i need one with 1+ year of warranty left - hmmm. BM52 |
I don't know an awful lot about these cheaper scan tools so can anyone with one confirm that they are generic/manufacturer specific or only read generic OBDII DTC's?
0 = Generic (The diagnostic codes that are required by law on all OBD II systems are "generic" in the sense that all vehicle manufacturers use the same common code list and the same 16-pin diagnostic connector. Thus, a P0301 misfire code on a Ford means the same thing on a Vauxhall, Citroen, Toyota or Mercedes.) 1 = Enhanced ( Each vehicle manufacturers also have the freedom to add their own "enhanced" codes to provide even more detailed information about various faults. Enhanced codes also cover non-emission related failures that occur outside the engine control system. These include ABS codes, HVAC codes, airbag codes and other body and electrical codes.) I know that the scangauge I have fitted only reads tested DTC's that illuminate the MIL and is restricted in what type 1 DTC's it shows. I do believe from looking at the scangauge site that its new generation of reader can also show pending DTC's HERE Also when buying something like a generic reader/OBDII plug and cable, it also needs to be compliant with the Ford J1850-PWM protocol or it wont work on the Puma. Ford vehicles from 1996 to 2002 almost exclusively used the PWM protocol. From 2003 to 2007 Ford vehicles will either support PWM or CAN, my Puma is a 2009 model and it uses PWM/CAN. If you are going to keep the Puma for a while why not buy a Nanocom as it does everything you will need to keep on top of faults on your Puma? Brian. |
| Molusk Member Since: 20 Dec 2011 Location: Loire Valley Posts: 43
Hello, I a am about to get a Scangauge II, but I do need the device to be able to help me in fault finding. So how can I be sure the Scangauge I am purchasing is able te read and clear both tested and untested (pending) DTC? Thanks for help, Julien. PS: what is the difference between tested and untested DTC? Are tested DTC faults about real defects that have still not been corrected, and untested DTC faults due to "one-shot" sensor value out of range for instance? |
