Home > Technical > Driven Gear - Green 21 teeth
drewster
Wales 1997 Defender 90 300 Tdi CSW Epsom Green
hi all i am running on 265 tyres and am looking to keep the speedo right would anyone be able to help
driven gear starts at 20 teeth and go up to 26 any ideas which one i need Big Cry Bow down
Post #90057 19th Sep 2011 8:16pm
twopoint6khz
United Kingdom 2005 Defender 110 Td5 CSW Java Black
It rather depends on what size tyres you are thinking of fitting?
Yellow is the correct cog if you're going down to 205/80R16, but I doubt that.
Post #90058 19th Sep 2011 8:21pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
This will tell you what the difference will be in your speed with different tyre size Thumbs Up
sorry can't tell you what driven gear you need
http://www.miata.net/garage/tirecalc.html NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #90068 19th Sep 2011 9:12pm
JSG
Re: Driven Gear - Green 21 teeth
If you are going from standard 235/85 to 265/75 then the speedo will still be ok as the rolling radius will be the same. John
2011 Tdci 110 CSW XS
Post #90173 20th Sep 2011 3:19pm
