![]() | Home > For Sale & Wanted > [SOLD] Air-Con Grille Surround ASJ710060 |
Shroppy Member Since: 25 Feb 2016 Location: Shropshire Posts: 878 ![]() ![]() ![]() |
I bought this ages ago, may have even been for my 110. Either way, it's new, a little dirty from storage but never fitted. I've no need to it so hopefully someone else will.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Shown here on the Bearmach site - https://bearmach.com/product/side-grilles-...-asj710060 It's certainly not the same as the factory fitted items but it is very well made, and you wouldn't know from the outside. Cheapest I can see on the web for this UK made variant is north of £100, would like £70. 1985 127 V8 Build Thread Series 2 109" Series 1 80" Last edited by Shroppy on 6th May 2021 11:16am. Edited 1 time in total |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3748 ![]() ![]() ![]() |
I don’t suppose you’ve got the brackets as well? Would you ship it?
The brackets are super easy to make Co1.
Piece of 15mm x 3mm steel bar and two rivnuts. I also have that very panel on Miffy, it does the job and took paint well. The only negative was that the upper mounting screw holes did not line up with the original ones on the slam panel. Sure I have photos somewhere if you are interested. |
I don't have the brackets sadly but they can be had relatively cheaply like these for example - https://bisonautodesign.co.uk/products/lan...t_campaign
Yes, happy to post. ![]() Re the holes, I think it depends on which slam panel you have - tdi, TD5, TDCI etc. 1985 127 V8 Build Thread Series 2 109" Series 1 80" |
I'll find a suitable box and drop you a PM Co1. 1985 127 V8 Build Thread
Sold to Co1. 1985 127 V8 Build Thread
