![]() | Home > Wheels & Tyres > Wheel rim choice. |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3591 ![]() ![]() ![]() |
ET 0 means that if you view from the front (or back) the centerline at tyre width will line up with the hub face.
ET greater than 0 (positive), the centre of the tyre width will move inwards relative to the hub face. So with ET15, assuming you have the same tyre, you should get 15mm more clearance (horizontal distance) from the wheel arch compared to ET0. The inner arch / the tub.. I think there is quite some clearance there. The vertical clearance between tyre and tub, that is mostly affected by tyre size... but can always fit thicker bump stops if the spring is being compressed fully when loaded and articulated. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11031 ![]() ![]() |
I understood all of that information, many thanks Dinnu
Sorry, I think it was obvious information.
Real life experience,, on a 90 however, with softer springs such that on full articulation, the wheels with load get compressed almost touching the standard bump stops. +2 shock absorbers, so the wheel with no load droops 2 inches more (effectively making the wheel on the opposite side (with load) to get closer to the tub / wheel arch. Standard boost alloys (ET33) but with 30mm spacers, so that would become same as an ET3. 285/75 tyres, and they just scrape the wheel arch at full articulation. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
So with me chopping and changing from day to day on what wheel rims to choose
![]() ![]() many thanks ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10384 ![]() ![]() |
Blondos are your normal genuine LR alloy nuts. QRZ 2e0vpf
Great, many thanks GREENI
Blondos
Iv'e got mine on and still i didn't see the mistake
So to bring this thread to a ending, i went for these
![]() Click image to enlarge ![]() Click image to enlarge Well chuffed with them ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2065 ![]() ![]() |
Oooh, ...very posh.
![]() ![]() Last edited by DAZ110 on 4th May 2021 9:33pm. Edited 1 time in total |
jimbo55 Member Since: 15 Jul 2020 Location: Midlands Posts: 405 ![]() ![]() |
Looking good Clayton, really suits the look of your truck 👍
Thank you DAZ and jimbo
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17885 ![]() ![]() ![]() |
Good choice!
