Home > Puma (Tdci) > BAS Intercooler Fitment
Page 2 of 2 <12
Angus_Beef
Norway 2015 Defender 110 Puma 2.2 SW Corris Grey
a ProTip from the Aussie forum... Apparently there is a personal lubricant called AstroLube with which you can "park a cadillac in a dog house."
Water based, no salt, dries after a bit. Apparently also good for installing intercooler hoses. Very Happy Roaming around 🇳🇴🇨🇭
Post #901272 4th May 2021 8:01am
kenzle8a
trailbear wrote:
Haha, perhaps I would need to leave them outside for the whole summer up here
In Scotland to make any difference Laughing
Its why one has an AGA, bottom oven is the best way to gently warm up things in Scotland.
Post #901273 4th May 2021 8:16am
trailbear
Yes, Ms Pharmacist I am looking for some Astro Lube, it’s for lubing up my hoses to get them ready for fitment.
Perhaps that statement may possibly be the cause of a future court appearance 😳
Post #901328 4th May 2021 3:29pm
piechipsandpeas
Australia 2013 Defender 110 Puma 2.2 SW Indus Silver
Just received mine today in the post, 7 days from ordering which I'm impressed with seeing how far it had to travel. Off work on Friday so we'll see how it goes fitting it.
Post #903901 19th May 2021 1:34pm
trailbear
I am currently waiting on a galvanised slam panel from YRM then I will fit it all at the same time, saves on dismantling twice.
come on YRM where are you....
Post #904050 20th May 2021 11:12am
bear100
Top tip.....fit the bonnet release cable guard at the same time Exclamation 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #904112 20th May 2021 4:56pm
trailbear
Yep, got it, ready and waiting to be fitted along with the rest Very Happy
Post #904156 20th May 2021 9:17pm
piechipsandpeas
Fitted the new BAS intercooler today, all went pretty smoothly. The only tricky bit, as experienced by others, being refitting the hoses onto the intercooler. The slam panel studs all came out easily using the 2 nut method, replaced with the BAS supplied bolts.
The old intercooler (original LR one) had quite a decent sized split in it.
The BAS one looks a quality unit and a fair improvement over the stock one, however the top trim panel on the new intercooler was loose when unpacked. Stuck it back on with some liquid nails stuff.
Hopefully the welding is better than the gluing. Wink
Fits neatly in place and I utilised the supplied spacer on the top AC securing bolt.
All put back together and a test drive shows normal power is restored.
Post #904273 21st May 2021 12:44pm
MatLandy
France 2008 Defender 110 Puma 2.4 CSW Zermatt Silver
Fitted one yesterday. Took me about 4hrs, taking it slowly to avoid damaging other parts.
As I have a/c, space is tight but I eventually managed to slot the massive BAS unit in. The silicone hose coming from the turbo was not cooperating and required some persuasion (brutal force). I did use a hacksaw wrapped in a rag to cut the two plastic lugs from the rad, as suggested above in this post (thanks for the tip).
However, I am interested to know how do you guys remove the bonnet slam panel? With the 2 bolts/studs either side being captive into the body, I have had to resolve tu use a pry bar to force the slam panel out. Didn’t seem right but couldn’t find a better solution at that time. See the 2 offending bolts/studs circled in red in attached picture.
Quick test drive didn’t show any difference in performance, and I didn’t expect any. However the little black smoke I had before when flooring it in 5th uphill seems to have disappeared. More driving in different conditions will be required to confirm though.
Post #904275 21st May 2021 12:52pm
Pacha
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
They are just studs - if you lock 2 nuts together they can be removed, swapped mine for bolts. Rgds.
Chris
Post #904277 21st May 2021 1:00pm
piechipsandpeas
MatLandy
To remove the studs wind 2 nuts onto the thread of one stud and then lock them against each other (use 2 spanners in opposite directions) then undo the stud by winding the innermost nut. It won't come off the stud as it's locked against the outer one. Once the stud is out you can unlock the nuts using the 2 spanners and reuse them on the next stud.
Post #904278 21st May 2021 1:00pm
MatLandy
Ahahaha … Thank you for clearing that! Hopefully it will benefit someone else.
As with most land rover things, it’s quite obvious once you know.
/Mat
Post #904280 21st May 2021 1:09pm
Bluericky
United Kingdom 2009 Defender 110 Puma 2.4 DCPU Keswick Green
Also just fitted the BAS intercooler and hoses to my 2.4 with aircon .
It took me a good four hours as well and I should say an hour of that was messing about putting the silicone hoses on, in particular the new jubilee clips which in my opinion should be more generous !!
Do line the bonnet catch up with the slam panel before tightening it and putting the grill back, it only needs to be a little bit off for it not to shut.
I went for it as I do a lot of towing up steep hills and along with the 170 HP remap (up from 150 HP) I didn’t want to Censored the engine .
It’s another huge leap in terms of drive-ability , 6th gear is a dream to use, cruising effortlessly along . The rest pull constantly until you change up, a pleasure to drive . https://www.instagram.com/hustynminepark/
Post #904314 21st May 2021 4:59pm
Page 2 of 2 <12
