Home > Puma (Tdci) > Engine cover question
Nevillerover
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Sumatra Black
I have searched forum but no result.
The cover on the top of a 2.4 is held by two bolts and I assume, a rubber thing or metal spring. Whatever it is, mine has fallen off.
Anyone know the part number please?
Post #900888 1st May 2021 3:59pm
It's a sort of rubber wedge-shaped prong thing that fits at the back of the cover and engages in a slot in the back of the cam carrier, as I recall. Also as I recall it is only available as part of the cover LBH500370 and not on its own, which is particularly unhelpful since the cover is around £50. It makes for a very expensive rubber prong.
I don't know if there is a Ford part number for the prong.
You can see the offending item in the photo below, at the bottom right.
Post #900897 1st May 2021 4:58pm
Nevillerover
Thank you, that’s it.
I will make one from something.
Post #900906 1st May 2021 5:59pm
Nevillerover
Just remembered, I’ve got some sugru, I’ll try that.
Post #900918 1st May 2021 6:47pm
