![]() | Home > Td5 > Oil leak/oil mist - rocker gasket half moon |
| Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3649
Recently replaced the top cover gasket on family Defender as it was also leaking from the half moon..
I added some sealant around the grommets as I was re using the old ones. IIRC the rear 2 bolts, the gasket is outboard of the 2 screws, so I suspected that the grommets should do a bit more sealing over there. Good luck. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
| geobloke Member Since: 06 Nov 2012 Location: Nottinghamshire Posts: 4410
It is worth saying at this point that some rocker cover gaskets are better than others, only I have found Britpart to be very good, not too soft.
Additionally, over-tightening the rocker cover can cause the seal to deform, especially the half moon (flexes outwards) portion and leaks will happen. The RC bolts are meant to be torqued down to just 9Nm (barely nipped up to most), above that and the gasket will deform. The good news is that the TD5 doesn't suffer from vacuum pump related over-pressurising like the 200 and 300 tdi engines. But, it is worth pondering on if your RC cover is properly installed, is the engine over-pressurising (RC being the weakest link) and what might be causing it?! Could just be heat due to re-mapping... or more suck from raising the turbo boost pressure... My TD5 breathes a little heavily and after 8 months of decent driving there was about 50ml of oil in the provent catch can. Not much but better in the provent than in the intercooler. Hate oil leaks |
| excossack Member Since: 22 Feb 2012 Location: North West Posts: 6043
Cheers Dinnu. I might just go for another gasket and more sealant.
GeoBloke - The td5 does have a mild tune +10-15bhp. I did use a torque wrench last time set to the correct setting and managed to shear a bolt. I don't have a Provent - maybe my intercool is self lubed…. Its quite annoying. Even using GenLR ones. With and without sealant it leaks! 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Sheared and RC bolt.... Blimey The provent (or knock-off versions) are a good idea and an easy mod. You'd be amazed how much oil ends up in your intercooler... I was... A good (and unfortunately retired) indy LR garage I was friendly with would always use Sikaflex sealer on the gaskets and I can promise you it worked well, too well.... Took ages to get the blinkin' RC off again Are you likely to do any deep water-crossings in the next month or so? If not, re-do the RC seal, torque it down and pop the RC hose in to a plastic bottle (wire wool inside would be good). Seal up the post-turbo connection. Drive around for a while and see if the RC seal leaks. If not then it isn't the turbo that is causing the oil to be pushed out the seal. Additionally you'll catch any oil coming down the RC pipe, which will be interesting to see how much oil is by-passing the RC baffles. Worth a play for the price of raiding the recycling box and a roll of electrical tape. |
Overt tightening the rocker cover bolts will not overcompress the gasket, as the screws fit over a grommet with metal bushing. The metal bushing is designed to provide the required compression of the gasket. Of course overtightening will cause other damage, worse case if you damage the face of the camshaft carrier.
Purchased both Britpart and Genuine. Britpart comes better packed, and as regards hardness, I think it was just a tad harder than genuine. I installed genuine, but did not unpack the britpart one, so did not have a closer check on quality. I like to apply a smear of RTV, just enough to give piece of mind. 9Nm is correct. My torque wrench starts at 10ftlb which is already 13.5Nm... just nip them by hand. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
No water crossings planned. But I like the idea of re-routing via tube via a bottle. I will have a look at that after the weekend at Donnington. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
I was just reading the Alive website and they even suggest this action:
I might consider venting to atmosphere myself for daily driving I thought you might also like to see the Provent setup whilst we are talking about it. What you can't see is the drain pipe and drain off tap that sits on top of the chassis rail. Click image to enlarge Click image to enlarge Click image to enlarge |
You are absolutely right Dinnu, my mistake, I had forgotten about those metal bushings and yes I went out to Miffy and double checked. I have not had two brands side by side, but it would be interesting to see whether they are exactly the same or more than likely not. Perhaps a test is required next service... |
Cheers Geobloke
So... From RC > pipe to Provent. Provent > drain pipe via a tap. and blanked off the original feed into the DCV ? Can turbos cause pressure to go back into the RC? And what is the orange pipe for around the radiator hose? 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
No problem
Pretty much. Although I have the complete circuit at the moment: RC > Provent > DCV > Turbo outlet I am going to give the venting to atmos and blanking at the DCV a go. Why not... Can always revert.
I wondered that as well... The question is what is inside the DCV? it must be a one-way valve, or is it?
Ah the orange pipe is in fact a clear pipe with anti-freeze in it. A while ago now during a service the original black coolant return pipe fractured, it was very brittle. So I replaced it with a clear pipe so I could see air bubbles bleeding back in to the expansion tank. At the time I was having a few over-pressurising moments that of course turned out to be a head gasket and the clear pipe was a window on what was going on. Not an essential mod but a handy diagnostic aide if required |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18038
Asked:
And answered:
Thank you for that Blackwolf, very interesting. If this is the case why would a very well known company be advertising and selling items for this exact procedure? I suppose it could be a case of it is "up to the owner" but still curious. I wonder once going through a Provent and a secondary filter how much "pollutant" would be left in the emission. Also I suppose under this legislation any EGR delete, de-cat or centre box removal and ECU remaps would also be frowned upon as they all alter the emissions of said vehicle too. Interesting. |
Update (at last)
I removed the pipe from the feeding into the DCV and with the engine at idle, I noticed some fumes(for want of a better word) exiting the pipe. No oil leaks from the half moon but I was at idle. I let the car idle for a few minutes while I checked screen wash etc. With the pipe re-reconnected the fumes then exited via the rear of the rocker gasket/half moon area. Not having any connectors or additonal piping I wasnt able to re-route the hoses to go for a run to really test for oil leaks. Not sure what this tells me other than the fumes don't appear to be getting sucked into the pipe work as much as they should be ? 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
| All times are GMT |
