|  | Home > Puma (Tdci) > TDCI 2.4 no fuel in rail or fuel up pipe |
| Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4341      | I think you need to use a bulb type primer to draw fuel through from the tank. The system won’t bleed with fuel pump suction alone. 2007 110 TDCi Station Wagon XS | ||
|  29th Apr 2021 8:58pm |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18058      | You can also pressurise the tank through the breather to bleed the fuel system. | ||
|  29th Apr 2021 10:07pm |
| MSmith7069 Member Since: 26 Apr 2021 Location: South Yorkshire Posts: 13      | Thanks for this reply, this is what I ended up doing and it has seemed to clear the air lock and is allowing the car to run normally.
 Is there any info on what could cause an air lock? I didn't move the car the last time it was used and ran the morning before it not starting. Any info so I can prevent this happening again as it was not an easy fix to do on a morning before I can get to work. | ||
|  9th May 2021 1:52pm |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554  |
 good link in this topic https://www.defender2.net/forum/post528968.html | ||
|  9th May 2021 5:16pm |
| MSmith7069 Member Since: 26 Apr 2021 Location: South Yorkshire Posts: 13      | For anyone following, it turned out to be the high pressure fuel pump. Whilst they are known for being pretty bombproof mine did end up going and wouldn’t allow the car to start at all.
 Good way to check, try gravity feeding in fuel and if stalls with Jerry can on the floor then pump not strong enough to pull the fuel up P.S don’t know anyone knows of someone who would take the old part to refurb it? | ||
|  6th Jul 2021 6:26pm |
| Posting Rules
