![]() | Home > Technical > Diagnostic port |
v8bob Member Since: 14 Mar 2018 Location: Midlands Posts: 342 ![]() ![]() ![]() |
If you are talking 2011 defender it is just below the steering column next to the fuses.
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2459 ![]() ![]() |
If you can find a local member with a nanocom set up for a puma you will be able to look up the last 5 events that caused the alarm to trigger. See first paragraph of page five of this document https://www.nanocom-diagnostics.com/upload...0Guide.pdf
For a 2011 puma you will have the green Lucas 10AS alarm module fitted. Being in Scotland it’s a bit far for me to travel to help you as I have a puma nanocom,but I’m sure there will be someone local who can. Just look at the nanocom group buy posts and that will give you an idea on members who have one. Ps. Probably a loose or damaged wire for one of the door switches or bonnet switch. And yes the OBDII port is in drivers footwell fuse box, to the left of the speaker. |
Tractorman Member Since: 08 Jul 2016 Location: Inverclyde Posts: 41 ![]() ![]() ![]() |
v8bob and Ianh many thanks indeed for your advice - this is what makes this Forum great! Regards
Jim |
