![]() | Home > Puma (Tdci) > 2.4 fuel pump cover in timing cover |
Badger110 Member Since: 06 Feb 2018 Location: South hams Posts: 1039 ![]() ![]() ![]() |
Hp fuel pump has a twist lock cover on the timing cover itself which is pretty crap if I'm honest and when refitting it's always worth sealing it up with some automotive silicone on the outside of it, the same goes for the front crankshaft seal outer body
The unfortunate news is you're going to need to remove the coolant pump again as the bolt that fits the idler assembly in front of it has a bolt sat behind this as well as the opposite side where the alternator will need to be removed. You can, with some fiddling remove the alternator and loosen that bolt and with an 8mm spanner get to the one behind the coolant pump to loosen it but you won't get it back in when you go tighten it all back up. On this screenshot it shows the one of the far right is behind the coolant pump pulley and the one on the left can only be accessed by removing the alternator ![]() Click image to enlarge Whilst you have the coolant pump off it's worth checking the rear of the 2 timing cover bolts that sit just by it, if the sealant used to seal the timing cover has begun to perish then these 2 bolts can weep oil from their rear as they go through the block and stick out. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17877 ![]() ![]() ![]() |
I've removed and refitted the pulley carrier plate without disturbing the coolant pump but it is very awkward to do and involves quite a lot of swearing.
