Home > Maintenance & Modifications > Prolonging the life of an old chassis
Mossberg
United Kingdom 1993 Defender 90 300 Tdi HT Aintree Green
What is the best way to prolong the life of my old chassis? I have just replaced the rear outriggers and the chassis is in better nick than I expected.
The chassis is rusted, I am not saying this has no corrosion but it does not have the amount I expected and I believe it is worth prolonging it life for a bit
So, what is a good method of slowing down its demise. It is rusted in some places more than others and I won't be able to get all the rust off. I will wire brush where I can but with the best will in the world I know it won't be back to bare steel.
So my thoughts are wire brush, rust treatment, red oxide, wax. Is that a good method.
Wax - do I use lanoguard, dinatrol, something else? I need the best to suit a chassis in state of repair mine is.
Then inside. I have no doubt this will be lots of rust and I can't wire brush that off, so what is the best for a 1993 chassis on the inside.
Looking forward to your suggestions.
My thanks.
Mick
Post #899796 24th Apr 2021 9:23am
Ianh
The first thing is to get the outside and inside of the chassis clean enough for any of the subsequent treatments to work effectively. That will involve jet washing or better still steam cleaning and then thoroughly drying out. So if diy you are going to need a few consecutive warm dry days.
Where you can’t get the rust off by hand you can use rust removal or treatment products. I like the bilt hamber range. https://www.bilthamber.com/.
Leave a few days then you can prime and paint with chassis paint. I like the corroless system , their primer and RF16 top coat https://www.arc-rite.co.uk/paints/automoti...t-products.
Leave a few weeks to cure as per paint system instructions.
After that it’s bilt hamber dynax S50 in the chassis, then it’s a choice of , bilt hamber, dinatrol or lanoguard as a top coat wax.
Everyone has their favourite products so I expect buzzweld chassis paint will get mentioned, as will heavy zinc based primers, frost paints etc etc. All work well if prepped and applied correctly.
Post #899807 24th Apr 2021 10:30am
PCM
Hi Mossberg
I'd really take it to an approved dinitrol centre. That way you're covered.
https://www.dinitroldirect.com/affiliated-...directory/
You can do it at home, but without a ramp and a steam cleaner I'm not sure if you'd ever get the same "stick"
Post #899809 24th Apr 2021 10:56am
Mo Murphy
Have you looked inside the chassis longitudinals ?
Land Rover chassis rust from the inside out so double check your chassis really is that good before splashing out hard earned on fancy wax treatments.
50 Shades of Pennine Grey
Post #899836 24th Apr 2021 1:47pm
G4V JW
PCM wrote:
Hi Mossberg
Cheers for this, just found a place on that list very close to me I wasn’t aware of, they offer a load of services and parts I’m after Thumbs Up Instagram; @gavin_walding
Post #899839 24th Apr 2021 2:11pm
PCM
Happy days.
Thumbs Up
Post #899840 24th Apr 2021 2:19pm
