![]() | Home > Td5 > TD5 stalls when I press the hand brake button !! |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2242 ![]() ![]() ![]() |
Almost certainly a bad seatbox/ECU earth. Probably earthing through the handbrake cable. 02' 110 TD5 Double Cab Rebuild Thread
jaygti Member Since: 04 Nov 2012 Location: essex Posts: 402 ![]() ![]() ![]() |
Yes it’s an earthing problem. Mine did it when I first got it. Easy fix too. 2002 td5 90 county hardtop
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2217 ![]() ![]() ![]() |
As above bad earth.
Its basically using the handbrake cable as the earth. Run a new one to the chassis. |
peterl Member Since: 08 Jan 2009 Location: Pembrokeshire Posts: 312 ![]() ![]() |
Thanks for that, as you all said, bad earth now fixed.
Thanks Pete |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 977 ![]() ![]() ![]() |
Gotta love this forum right?
![]() 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
