Home > For Sale & Wanted > [For Sale] Assorted 300tdi parts
Alex1976
I have a job lot of assorted parts that are mainly for a Defender 300tdi but many of that parts will fit others too. The lot consists of all new boxed parts as follows:
1 qty PRC7370 wiper arm control stalk - Bearmach
1 pair front brake discs - Britpart
1 pair rear brake callipers - Britpart
2 qty RTC3429 wheel bearings - Timken
1 qty ESR2623 Air filter Mahle
2 qty AEU2147 fuel filter Mahle
1 qty ERR4708 serpentine belt tensioner - Allmakes
1 qty ERR3785 manifold gasket - Britpart
1 qty PEB50090 water pump and P gasket - Airtec OEM
1 qty ERR5057 fuel pump - Delphi OEM
1 qty NRC4251 brake pipe - Britpart
1 qty KQB500550 gearbox mounting - Allmakes
1 qty ERR3340 oil filter - Coopers
1 pair galvanised bulkhead to chassis mounting brackets - YRM
2 qty RTC3458 Universal Joints for props. - GKN
10 qty TE11071 manifold studs
1 qty NTC7161 Expansion cap - Britpart
2 qty STC987 wiper arm spindles - Britpart
4 qty ERR2337 air filter mounting bobbins - Britpart
10 qty UYG500030 brake disc to hub bolts - Britpart
1 qty WLR000020 seal - Genuine LR
4 qty HD track rod ends - Gwyn Lewis
1 Qty ANR3200 gearbox mount - Britpart
1 qty STC1453 washer pump - Britpart.
1 qty MRC9833 body mount fitting - Britpart
1 qty RTC wiper motor - Lucas OEM
1 pair RTC4685 front mud flaps - Allmakes
20 qty prop shaft bolts - Bearmach
1 qty EJS000011 door lock housing - Britpart
1 Qty QRJ500010 steering lock clamp. - Britpart
1 qty FTC4785 hub oil seal - Allmakes
7 qty FTC3179 hub lock washer - Allmakes
1 qty AWR2215 wing top vent panel - Bearmach
1 qty BR1288 windscreen rubber seal - Bearmach
1 qty - ERR6818 rear main crank seal - Bearmach
1 qty ERR716 timing housing cover - Britpart
1 qty PRC4276 wiper arm - Genuine LR
1 qty MXC4738 door lock surround - Britpart.
1 qty STC592 heater unit seal to bulkhead - Britpart
1 qty STC617 door lock seal - Britpart
1 qty ERR4576 crank seal - Britpart
1 qty LR034309 washer jet unit - Allmakes
1 qty JRC1775 lock pull - Britpart
10 qty FTC3375 calliper bolts - OEM
2 qty RTC3511 seal - Bearmach
3 qty BR2378 wiper blade - Bearmach
1 qty STC8574 brake pad retaining kit - Allmakes
3 qty NTC9208 power steering pipe brackets - Genuine LR
1 qty RTC5001 brake pad retaining kit. - OEM
1 qty NTC1773 poly bush
1 qty ANR3410 poly bush
1 qty NRC5593 poly bush
1 qty 552819 poly bush.
Collection only from Buckingham MK18.
£100
Post #899384 21st Apr 2021 7:13pm
darthdicky
I’m interested but nowhere near you. Any chance of posting it?
Richard
Post #899451 22nd Apr 2021 7:27am
Alex1976
Hi Richard,
Sorry, this really is collection only as it weighs a lot - as in beyond normal parcel limits and therefore probably special courier.
Alex
Post #899455 22nd Apr 2021 7:53am
Mo Murphy
Dicky I might be able to grab it for you as I work in Milton Keynes.
50 Shades of Pennine Grey
Post #899464 22nd Apr 2021 8:35am
darthdicky
Thanks Mo, John B has also offered but if you’re nearby that would be great!
Richard
Post #899467 22nd Apr 2021 8:45am
Alex1976
Sorry, already agreed for a collection sale, so now sold unless it falls through.
Post #899471 22nd Apr 2021 9:07am
