Home > Puma (Tdci) > Tdci 2.4 white smoke on startup
Willfindlay
England 2009 Defender 90 Puma 2.4 PU Arles Blue
My 2009 2.4 has had quite a lot of white smoke on startup, but as soon as you set off it disappears and there is no smoke once the engine is warmed up. The engine never runs hot, and the coolant levels are all correct. I was wondering if anyone knows the reason for the smoke on startup. Thanks
Post #898289 14th Apr 2021 8:51pm
Caterham
I stand to be corrected but I think its just part of the engine 'calibration' - presumably only happens when it cold ambient / weather?
Post #898855 18th Apr 2021 11:46am
andydef90
United Kingdom 2014 Defender 90 Puma 2.2 HT Corris Grey
as above long as in only cold weather no problem Smile
Post #898870 18th Apr 2021 3:19pm
ericvv
When very cold, meaning minus 5°C or so, and when the truck is thoroughly cold, I have a puff of blue smoke at startup. Stays like that for 10-20 seconds while slowly backing out of the driveway, but thereafter it immediately disappears entirely. When temps are positive it does not happen at all. Presume also a normal occurrence?
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #898877 18th Apr 2021 4:57pm
Leamreject
Italy 2011 Defender 90 Puma 2.4 HT Fuji White
My 2.4 is the same in very cold weather, I keep an eye on levels etc and it goes within a few mins.
Could be a lazy injector but I’m not going to worry about it. Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do…
2011 2.4 Puma 90 HT
Post #898878 18th Apr 2021 4:59pm
Defender_Ambo
United Kingdom 2010 Defender 130 Puma 2.4 HCPU Alaska White
I have a fleet of 7 and they all do the same 😊👍
Post #898929 19th Apr 2021 2:07am
